August 22, 2025, 05:15:33 AM *
Author Topic: Hood lining SWAP  (Read 3355 times)
giddyup
« on: March 27, 2015, 04:24:55 PM »
Hi all,
I am after a hood lining for an FC van.
I have a complete FC wagon lining all complete with supports and in pretty good nic.
Can supply photos.
Happy to do a swap as I do not want destroy the wagon one to make up for the van.
I am in Sydney so I guess some one close as too fragile to post.
Cheers Mark.
« Reply #1 on: March 27, 2015, 09:49:14 PM »
What colour are you after? I have a green wagon lining that is ripped at the front but the rear is still ok.
giddyup
« Reply #2 on: March 27, 2015, 10:06:40 PM »
Mine is the white cream and I am after this colour,
ripped front is no good to me as this is the section I need, if the rear is ripped then happy to swap.
fink
« Reply #3 on: March 27, 2015, 11:24:55 PM »
You can fit the complete wagon rooflining and do a color change as long as there's no shrinkage and the backing has not rotted where your hood bows slide through,you can buy the clips that go around the edges,it comes in a roll,good luck,Gaz!
« Reply #4 on: March 28, 2015, 08:53:48 AM »
That might not work as there is a stitched seam in the PV roof lining that a retaining wire fits into.
I still have some repro off-white roof lining in stock, a PV roof lining is $190 plus postage.
FE/FC Roof lining - Off white
giddyup
« Reply #5 on: March 28, 2015, 08:56:09 PM »
Hi Stinky,
I have checked the hood lining and I can make it work.
Thanks for your offer if I fail ( hopefully not ) then I will chase you up for one.
Thanks Mark.
Page created in 0.028 seconds with 20 queries.
