August 27, 2025, 03:38:16 PM *
Pages: 1 [2] 3 4   Go Down
Author Topic: Grey motor bits and pieces -Ebay Gumtree Finds  (Read 98815 times)
TassEK
« Reply #20 on: June 19, 2015, 07:18:05 PM »
Motor and gearbox in the central highlands - $585
http://www.ebay.com.au/itm/Holden-138-Grey-Motor-and-Gearbox-/141693632997?pt=LH_DefaultDomain_15&hash=item20fd9941e5
Motor and box -Smithfield NSW - bids at $670
http://www.ebay.com.au/itm/X532-1948-63-HOLDEN-FX-FJ-FE-FC-FB-EK-EJ-STANDARD-6-CYL-138-GREY-MOTOR-RUNNER-/181776024766?pt=LH_DefaultDomain_15&hash=item2a52b204be
TassEK
« Reply #21 on: June 22, 2015, 08:42:14 PM »
Head that looks clean but description says "It will need reconditioning and -  may need a crack or two pinned - like most grey heads"  Pick up only Palm Beach NSW so am thinking there may be  crack or two to deal with.
http://www.ebay.com.au/itm/Holden-Grey-Motor-Cyl-Head-FX-FJ-FE-FC-FB-/181781682179?pt=LH_DefaultDomain_15&hash=item2a53085803
The same deal with this head:
http://www.ebay.com.au/itm/Holden-Grey-Motor-Cyl-Head-FX-FJ-FE-FC-FB-EK-/181781681146?pt=LH_DefaultDomain_15&hash=item2a530853fa
TassEK
« Reply #22 on: July 03, 2015, 09:57:17 PM »
Motor in the West - Goomalling
http://www.gumtree.com.au/s-ad/goomalling/engine-engine-parts-transmission/holden-fc-fb-138-cui-grey-motor/1082831899
TassEK
« Reply #23 on: July 26, 2015, 07:27:40 PM »
Couple of heads and a manifold at Brisbane
http://www.ebay.com.au/itm/HOLDEN-FB-EK-EJ-GREY-MOTOR-HEADS-X2-/281756487821?pt=LH_DefaultDomain_15&hash=item4199fed08d
A Head and some bits at Kangaroo Flats Vic - bit on the rusty side
http://www.ebay.com.au/itm/GREY-MOTOR-HEAD-AND-LUCAS-STARTER-MOTOR-No-Solonoid-/281758391773?hash=item419a1bdddd
GreyFC
« Reply #24 on: July 29, 2015, 02:37:06 PM »
For $20 I'd still take it and chuck it in molasis.
TassEK
« Reply #25 on: July 29, 2015, 08:42:41 PM »
Motor and some bits and pieces at Korumburra Victoria.
http://www.ebay.com.au/itm/Holden-FB-EK-Grey-Motor-/252040103477?hash=item3aaec2c635
TassEK
« Reply #26 on: August 12, 2015, 07:58:39 PM »
Motor and gearbox at Highbury WA
http://www.gumtree.com.au/s-ad/highbury/engine-engine-parts-transmission/holden-138-grey-motor-/1085270451
What is it about the  West here is another one - an EJ motor that is cheap at Bibra Lake WA
http://www.gumtree.com.au/s-ad/bibra-lake/engine-engine-parts-transmission/holden-ej-138-grey-motor/1086115654
This one at Walliston WA
http://www.gumtree.com.au/s-ad/walliston/engine-engine-parts-transmission/holden-grey-motor/1073652675
Here are some garden orniments at Windsor Brissy - but you never know there may be something salvageable in the EJ gearbox or the rusty short block and the head may be intact on the rusty complete motor .
Happy hunting
http://www.gumtree.com.au/s-ad/brisbane-region/engine-engine-parts-transmission/ej-eh-gearbox-and-grey-motors-x2/1084358700
« Last Edit: August 12, 2015, 08:10:15 PM by TassEK » Logged
TassEK
« Reply #27 on: August 24, 2015, 08:37:50 PM »
Motor and gearbox in Orangeville NSW - says FC motor and from the dust has been stored for some time.
http://www.gumtree.com.au/s-ad/orangeville/engine-engine-parts-transmission/holden-other-sedan/1087376607
TassEK
« Reply #28 on: September 16, 2015, 09:21:00 PM »
Here is a pretty little motor at Bayside, Melb, Victoria - missing genny, starter or fuel pump - has a spare dizzy, and carbbie - anyway the lot has been stored for 40 odd years.
Starting bid is currently $150 - good buying at that price hell a dodgey head will set you back that if you are lucky.
http://www.ebay.com.au/itm/Grey-Motor-H ... 33a980ac22
There are 3 motors at Newlands Arm, VIC - Starting bid is currently $100. Ok probably only end up with one good'un
http://www.ebay.com.au/itm/Holden-Grey- ... 1887114274
There is this "reconditioned" head at Enoggera Briz. The description sounds like it has been given the full treatment. Oversized ported valves with hardened seats - wonder why the price is so low.$ 150
http://www.gumtree.com.au/s-ad/the-gap/ ... 1082211289
collecta
« Reply #29 on: September 16, 2015, 09:41:00 PM »
 Must have been a typo Grey motor head is now $850
TassEK
« Reply #30 on: September 21, 2015, 07:55:11 PM »
Probably mine.
This one has a starting bid of $80 but looks ok- it is at Laverton Melbourne
http://www.ebay.com.au/itm/HOLDEN-GREY-MOTOR-HEAD-/131608495620?hash=item1ea47a4604
I am tempted to bid actually
TassEK
« Reply #31 on: October 05, 2015, 08:07:08 PM »
Here is an FB motor and gearbox @ Epping VIC - on Ebay This seller is a wrecker and has a store
http://www.ebay.com.au/itm/Holden-SPECIAL-FB-Engine-and-Gearbox-/321884656572?hash=item4af1d213bc
TassEK
« Reply #32 on: October 05, 2015, 08:35:21 PM »
This may be a little on the expensive side but with the twin strommies (Extractors are chucked in) Finned rocker cover and there are other parts available could be a decant contact if you are looking for something.
http://www.gumtree.com.au/s-ad/busselton/engine-engine-parts-transmission/holden-fc-motor-complete-twin-carbs-extractors-alloy-rocker-cover/1091137864
TassEK
« Reply #33 on: October 12, 2015, 08:20:09 PM »
Here is a collection of Rusty parts, that have been left out in the rain for some time by the looks, for those in Tasmania  - Rusty motors,(2Grey 2 Red) crusty gearboxes (4 EK FB)(EH) and couple of radiators.
http://www.gumtree.com.au/s-ad/buckland/engine-engine-parts-transmission/holden-early-fb-ek-parts/1091623616
TassEK
« Reply #34 on: November 12, 2015, 09:15:12 PM »
Here is a grey with hydramatic at Tatura, VIC, which is a bit of a lottery as it is bowing air through the carbbie seller hasn't done any investigation.
Starting bid is $200 so might have the parts you are looking for like a hydramatic.
http://www.ebay.com.au/itm/Holden-grey-motor-hydramatic-automatic-transmission-138-fx-fj-fe-fc-fb-ek-ej-/191736079701?hash=item2ca45c6555:g:nwMAAOSwAYtWQtBE
I did smile at this bit - "Has been dry stored for the last 7 years. I was going to restore the car but a tree fell on it so motor and box is now surplus. Pick up only"
This one is at Lismore NSW and has a few issues but not insummountable
http://www.ebay.com.au/itm/Holden-Grey-Motor-/161884354795?hash=item25b10f38eb:g:f-oAAOSw~bFWQwA2
TassEK
« Reply #35 on: November 22, 2015, 09:14:35 PM »
There is someone in Brissy selling a motor a piece at a time.It is an EJ motor so if you are a welded on originalist (Yes it is a made up word )may not be for you.
Short block
http://www.ebay.com.au/itm/short-Holden-grey-motor-With-clutch-flywheel-water-pump-harmonic-balancer-/121820433343?hash=item1c5d104bbf:g:KfYAAOSwcBhWT-EX
Head some rust in 4 poy.
http://www.ebay.com.au/itm/Holden-grey-motor-cylinder-head-out-of-an-EJ-/121820504570?hash=item1c5d1161fa:g:3PYAAOSw585WT~ly
There are more but the starting bids on these look reasonable-
TassEK
« Reply #36 on: November 25, 2015, 08:09:31 PM »
Cheap motor and gearbox at Northern Beaches Sydney
http://www.ebay.com.au/itm/HOLDEN-MOTOR-FC-/221946515523?hash=item33ad0b1043:g:npwAAOSwkZhWS~Nr
More expensive at Ballrat Vic
http://www.ebay.com.au/itm/Holden-Grey-Motor-And-Box-FX-FJ-FE-FC-FB-EK-EJ-EH-132-138-/262159318669?hash=item3d09e9be8d:g:TzgAAOSwv-NWVOot
TassEK
« Reply #37 on: December 07, 2015, 10:42:29 PM »
Here are some bits that seem cheap on Gumtree-  at Paralowe SA
Couple of heads, sump
http://www.gumtree.com.au/s-ad/paralowie/other-parts-accessories/holden-grey-motor-fx-fj-fe-fc-fb-ek-ej-heads-sump-timing-nasco/1097402795
TassEK
« Reply #38 on: December 10, 2015, 05:16:19 PM »
Here is a reasonable looking motor and box at Banyo Brisbane - Although seller is saying it is an as is, "restorable" motor
http://www.ebay.com.au/itm/Holden-Grey-Motor-FX-FJ-FE-FC-FB-EK-EJ-/221963968473?hash=item33ae155fd9:g:VlkAAOSwp5JWaAaq
TassEK
« Reply #39 on: December 16, 2015, 02:08:44 PM »
Motor and gearbox that seem like a reasonable example. In THIRLMERE, NSW, Australia
http://www.ebay.com.au/itm/Holden-grey-motor-FB-EK-may-suit-rat-rod-/291639909882?hash=item43e717ddfa:g:WDUAAOSwCQNWcLFW
Pages: 1 [2] 3 4   Go Up
