September 07, 2025, 07:19:43 PM *
Author Topic: power windows  (Read 3683 times)
cruiser
« on: March 14, 2015, 11:31:45 AM »
what is the power window mechanism used for fc finding it hard to get a straight one
« Reply #1 on: March 14, 2015, 01:10:29 PM »
Are you talking about a switch or a motor? Neither are standard. Use what you can get to fit.
I used a 97 Sonata power window motor with a micro switch from auto loc that a manual winder can mount to.
« Reply #2 on: March 14, 2015, 01:50:22 PM »
Have a look at my fc rebuild page 10. I did the same as Nes but without the outer skins so it shows the whole setup. I used the sonata fronts and civic rears and the auto lock switches. All I did was put the runner between two bits of 4x2 timber and stood on it to flatten the runner out.
cruiser
« Reply #3 on: March 14, 2015, 04:09:08 PM »
thanks for the information I shall have a look at your sugestions
« Reply #4 on: March 14, 2015, 06:07:01 PM »
Two things I would watch for . When making brackets to mount your mechanisms ,clamp them in position with vice grips and use some jumper leads to check they work before final weld and remember that the glass still needs to fit in and out with the brackets welded and or bolted in place .Seems so obvious when I write it down .Cheers Haydn
« Reply #5 on: March 14, 2015, 07:35:30 PM »
Exactly why I didn't weld in!!
« Reply #6 on: March 14, 2015, 07:37:32 PM »
Yup, I screwed in the brackets... Works a treat!
