August 09, 2025, 07:58:34 PM *
Author Topic: Rear boot panel and boot extension panels wanted.  (Read 7400 times)
Stash
Sydney, NSW
johnchaplin
« on: February 15, 2015, 09:47:31 PM »
I am after these panels if possible:
1x Boot rear panel. The one that has a hole for the petrol filler
It has a 90 bend along the edge.
L & R Boot extension panel. as you can these are rusted out on mine. (and probably on most)
PM if you can help
Stash
Re:
« Reply #1 on: February 21, 2015, 02:58:32 PM »
You can't buy these they gotta get cut from a good car or made. You might be best cutting the lip out at the corner and welding a new folded and shaped bit back in. I'm about to do a section of mine maybe late this month and I am borrowing a mates engineering joint which has all the gear. So I'll ask him about it for you. If he says it's easier to do a whole piece then I'll do you one if it's not too Labour intensive (I'm already doing 2 at once 😨 cos I'm stupid) but my son is pretty crook so I've dropped behind. I have a question. Has it been blasted yet? Can you pm me better pics say along 3 sections along boot lip and mark the rust holes on the panel part. With my custom fe, I was gunna cut the whole section out on one side to make a battery or other compartment for whatever, but my concern is if it's boxed up too much, it might look funny from the side. So can u also pm me better pics of both sides then I'll compare to mine and I could possibly make some more but I wasn't planning on spot welding but plug welding but we have the ability to spot but I don't see the point if you get me. I'll try help you but hesitant as I don't know you if u get me. It's a tricky section depending on where it's stuffed. If you have pin holes sporadic on the outer, just drill holes in them and weld them with mig. Then we could send you the inners. Send pics anyway and I'll show the guys and maybe come up with some sort of a quote but I'm not quite up to that yet so not sure of your timeframe.
Stash
Sydney, NSW
johnchaplin
« Reply #2 on: January 29, 2017, 11:12:13 AM »
Thanks for the comments fe350chev... albeit late.
Bump!!! Still looking for back panel with the petrol hole and left rear lower quarter.
Also if anyone has a tyre well, would be interested in that.
« Reply #3 on: January 30, 2017, 01:36:34 PM »
I might have a tyre well, I'll check and let you know.
« Reply #4 on: January 31, 2017, 11:14:20 AM »
You could try Shane's Metal Fabrication on Facebook for the other gear, Adelaide guy.
collecta
« Reply #5 on: January 31, 2017, 12:55:42 PM »
What happened to the spotless tyre well i gave you?
Stash
Sydney, NSW
johnchaplin
« Reply #6 on: February 07, 2017, 06:07:06 PM »
Thanks Stinky.
Stash
Sydney, NSW
johnchaplin
« Reply #7 on: February 07, 2017, 06:07:47 PM »
@Collecta I might have to check. I dont think i have a tyre well.
collecta
« Reply #8 on: February 08, 2017, 01:41:37 AM »
I definitely gave you one, still have the shell i took it out of.
Stash
Sydney, NSW
johnchaplin
« Reply #9 on: February 08, 2017, 09:21:35 AM »
if you saw so Scotty...
I will check. down in Adelaide next week.
Stash
Sydney, NSW
johnchaplin
« Reply #10 on: February 08, 2017, 09:25:22 AM »
say.. Huh
Stash
Sydney, NSW
johnchaplin
« Reply #11 on: March 15, 2017, 01:43:55 PM »
@Collecta - Scotty - i stand corrected.
There is a beautiful new tyre well in the boot!!
thanks 1m x
Stash
Sydney, NSW
johnchaplin
« Reply #12 on: March 15, 2017, 01:44:50 PM »
Does anyone have a good boot rear panel?
or left rear quarter and inner?
Page created in 0.023 seconds with 18 queries.
