June 06, 2025, 09:12:48 PM *
Pages: 1 [2]   Go Down
Author Topic: enguiry  (Read 16540 times)
justin09
« Reply #20 on: January 20, 2015, 01:57:10 PM »
Hi just wondering if anyone has pictures of engine mounts for an rb into fe at all thanx been looking and haven't found any yet also gearbox mount or would that be an easy make. Thanx alot
« Reply #21 on: January 20, 2015, 02:10:20 PM »
Hey Justin;
Mate speak to Pete Mallaby Pete has a RB30 I believe in his sedan he may be able to help
Neil H
justin09
« Reply #22 on: January 20, 2015, 02:13:15 PM »
Ok no worries im in qld as just trying to plan my build
Ol_Girl_58
getting there...
« Reply #23 on: January 20, 2015, 04:55:42 PM »
Pedro and Jox, also.  Smiley
JOX515
« Reply #24 on: January 20, 2015, 09:28:57 PM »
G'day Justin,
My engine mounts for the RB30 motor came from Castlemaine Rod Shop - bolted straight up and came certified for engineering. I was already running a red motor, so the mounts on the front end had been moved back.
I used the RB30 gearbox mount and had a mate weld up some additional bits - was fairly simple but very solid and works well.
You could probably get all you need - engine mounts, gearbox cross member, etc from CRS or similar places.  The most important thing before you buy anything is have a well documented and thought out plan and stick to it.  Some of this stuff can be very costly and once you start cutting things up, there is no turning back........
But it is all good fun and very rewarding when finished  Grin
Good luck with your build,
Cheers, Graeme (JOX515)
justin09
« Reply #25 on: January 20, 2015, 11:21:17 PM »
Thanx mate my mounts have alr3ady been moved back and welded into place was just seeing how the engine mount bolts onto the cross member thats all thanx.
Pages: 1 [2]   Go Up
Page created in 0.038 seconds with 16 queries.
