May 21, 2025, 12:58:49 PM *
Author Topic: commodor discs to hr front end  (Read 5690 times)
parry
« on: December 24, 2014, 08:11:39 PM »
Hi all just finished modifying my VN commodore diff fits in well so easy to shorten now to the front end do I need to change my stub axles to HQ to fit VN discs have HG on at present.
Parry
« Reply #1 on: December 24, 2014, 08:26:38 PM »
Parry, the VN discs fit OK on the stubs, it's the calipers which need a custom mounting bracket. Even if you use the HQ stubs, you will still need a bracket for the calipers.
Commodore discs are slightly smaller in diameter, thinner and have a different offset.
parry
« Reply #2 on: December 24, 2014, 09:04:47 PM »
Thanks Ken the VN calliper sits in the same place as the HG but only one bolt hole  lines up ,can't see how u can make an  adapter for this
« Reply #3 on: December 24, 2014, 09:55:19 PM »
Adapters are readily avail from v6conversions and are relatively cheap
« Reply #4 on: December 25, 2014, 09:05:16 AM »
We used to make them to fit the drum brake stubs so as to have the large bolt hole at the top as the other mounting point .Cheers Haydn
Re:
« Reply #5 on: December 25, 2014, 09:47:29 AM »
If I was home I could take a pic of my stubs. But I'm away.
« Reply #6 on: December 25, 2014, 07:00:25 PM »
Heres a blank one I havent drilled and tapped yet
Top hole is bolt on the top of the stubb
Front 2 calliper
Lower 2 steering arm
FireKraka
« Reply #7 on: December 28, 2014, 01:42:23 PM »
My 2cents worth on this subject.
Just remember if you use the drum brake stub axles you have to machine down the top mounting hole spigget so that the adapter plate 1 sits in the same plane as the lower steering arm mounting holes and 2 by doing this it should line up the caliper with the disc.
I have gone this way with my EK ute and it works great.
My FC sedan runs HZ/WB stub axles and the girl ok aluminium caliper this also works great.
Neil H
Re:
« Reply #8 on: December 28, 2014, 06:50:17 PM »
Have u noticed much difference between the performance of hz vs commo brakes?
parry
« Reply #9 on: December 29, 2014, 02:09:54 PM »
I've got HG disc set up and have changed to commodore VN discs and callipers. The bracket Guru posted looks interesting will this effect your steering , what calliper do you recommend I have both VN & HG here was looking at putting a spacer in the HG callipers and putting them back on as there twin piston.
Parry
