May 22, 2025, 06:56:35 AM *
Author Topic: Like a Boss  (Read 2152 times)
« on: November 09, 2014, 09:23:54 AM »
I am tidying up a Thomas Twin Stromberg manifold for polishing and want to know if the boss in the picture (on the side of the manifold just forward of the front carb) is important and if I can remove it and still have a functioning twin carb setup.
Online Online
« Reply #1 on: November 09, 2014, 10:48:01 AM »
Is there one on the other end of the manifold? Looks like an (un-machined) boss to mount the linkage rod for married linkage.
If this is the case, you can remove it. Just double check it's not hollow inside before cutting it off (feel though the carb hole with a bit of wire).
It will mean though that you will need to run married linkage on the carbs (W-clip type) rather than divorced linkage.
The only other thing that comes to mind is that it appears from the flange to be a red motor manifold - some of these were water heated. It's not an (unmachined) water jacket outlet is it?
« Reply #2 on: November 09, 2014, 11:22:51 PM »
Thanks Harv, it is a solitary boss, not hollow. The carbs that came with the manifold have the W-clip style link that you describe.
Page created in 0.037 seconds with 20 queries.
