September 09, 2025, 06:47:31 PM *
Author Topic: Grey motor to 350 holley manifold.  (Read 59936 times)
« on: November 04, 2014, 07:58:53 PM »
Paul conned me into making him a 350 to grey motor manifold so i knocked one up from stainless then bead blasted it to look like cast alloy.
I really enjoy these custom 1 offs
But this will be the last for a while till my cars done.
Im unsure how it will perform but i made everything nice and smooth inside tigged everything up so it looks pretty.
Should be nice and strong as well.
Weld bosses under the holes.
I had to cut a 6mm alloy spacer as the throttle bkt on both sides of the butterfly clipped the manifold face. (made sense to me)
This one shows my gun tig welds on the flanged also tigged inside. Then faced the flanges off so it will seal perfect.
« Last Edit: November 04, 2014, 08:04:36 PM by FCRB26 » Logged
« Reply #1 on: November 04, 2014, 09:09:23 PM »
Very, very cool  Cool.
DJ
« Reply #2 on: November 04, 2014, 09:43:26 PM »
Small lunch break job to fill in the time? Looks a million.
0417 270 315
Re:
« Reply #3 on: November 04, 2014, 09:51:54 PM »
The other day I tried tigging some .8mm butted up without using filler. I got no foot pedal though.
« Reply #4 on: November 04, 2014, 09:52:04 PM »
This one took a while.
JOX515
« Reply #5 on: November 04, 2014, 09:55:34 PM »
genius seems to be an understatement for you Pete  Grin
« Reply #6 on: November 05, 2014, 07:18:37 AM »
There is an original cast dual throat manifold on eBay at the moment, no where near as good looking as yours.
GreyFC
« Reply #7 on: November 05, 2014, 09:25:55 AM »
It will make me very happy.  Thanks Pete.  And they say you can't run a 350 holly on a Grey.
GreyFC
« Reply #8 on: November 05, 2014, 09:30:46 AM »
That one has the carby the other way so I would need a cable to operate it.  The one Pete made I can use the accelerator rod.  Kerry Park suggested the carby sit that way aswell.  It should go well!
« Reply #9 on: November 05, 2014, 10:06:02 AM »
Got a link to the eBay manifold?
Sounds like the eBay one is mounted with the fuelbowl in the east/west orientation (facing the mudguards), whilst Pete's puts the fuelbowl north/south (facing the radiator). The fuelbowl on the 350 Holley carburettor is of the center-pivot type. Running a north/south orientation (like Pete's) is best for speedway, gymkhana or road racing where fuel sloshing is from side-to-side. In drag racing applications, the front-to-back sloshing of fuel (and lifting of the nose of the car) can cause this type of float to not operate as effectively unless the east/west orientation is used. This is amplified if meth is used, as the fuelbowl holdup time is effectively halved (the engine thinks the fuelbowl is half the size of a petrol one).
GreyFC
« Reply #10 on: November 05, 2014, 10:37:39 AM »
http://www.ebay.com.au/itm/Fx-fj-fe-fc-fb-ek-ej-holden-/251701624268?pt=AU_Car_Parts_Accessories&hash=item3a9a95fdcc
« Reply #11 on: November 05, 2014, 10:41:13 AM »
Yuck
GreyFC
« Reply #12 on: November 05, 2014, 10:58:16 AM »
Looks like a standard mani modified.  It's also not a 350 it's something else.
« Reply #13 on: November 05, 2014, 11:52:47 AM »
Looks more like a Falcon Weber. The mild steel to cast iron weld must have been an interesting one to do.
Re:
« Reply #14 on: November 05, 2014, 02:19:32 PM »
I'm going for a Weber on an aftermarket sonic manifold.
GreyFC
« Reply #15 on: November 05, 2014, 02:28:17 PM »
Brett ( Sonic Injection ) is a good guy, very friendly and also loves grey motors.  He is working on a turbo kit for the grey.
Re:
« Reply #16 on: November 06, 2014, 10:10:30 AM »
He is a nice bloke and willing to help.
Neil FE Van
« Reply #17 on: January 06, 2015, 07:34:30 PM »
Looks like a Holley to me.
Neil
Page created in 0.052 seconds with 16 queries.
