August 06, 2025, 07:10:06 AM *
Author Topic: brakes again  (Read 1535 times)
freddyc
« on: September 21, 2014, 09:53:29 AM »
This has probably been asked before. I have 2inch drop stubs that take hq-wb callipers. I have a shortened  vn commodore diff, apart from having to machine the centre bore down on the front disc to take commodore rims can this combination work together?
fred
Townsville North Queensland
FireKraka
« Reply #1 on: September 21, 2014, 10:47:28 AM »
Hi Fred
I am running the same setup on my sedan with a rear mounted rack but I run the HZ WB discs and I changed the rear wheel studs to the same there are plenty of rim choices now.
I believe the stud pattern is the same just studs slightly bigger.
I haven't heard of machining down the front disc but then again I don't know everything somebody else may be able to explain.
Neil H
Page created in 0.044 seconds with 16 queries.
