July 18, 2025, 10:14:34 PM *
Author Topic: Cowl Vent Install  (Read 2895 times)
smitty
« on: September 06, 2014, 02:17:43 PM »
Just wondering if anyone knows what kind of Bolt/screw/rivet holds the cowl vent insert on the hinge brackets?
There is two holes that are not threaded so would assume a bolt but don't have any here that fit?
Amy advice much appreciated!
Mark
Stewy
sa-club
Jeff Stewart
« Reply #1 on: September 06, 2014, 02:37:16 PM »
Hi Mark, parts book says   Screw  -  Truss head, cross recess mach.No. 10-32 x 3/8" with lock washer.
                                       Nut  -  Hex. machine screw No. 10 - 32
Hope this helps Cheers Stewy   Cool
smitty
« Reply #2 on: September 06, 2014, 03:01:21 PM »
Thanks Stewy, very helpful!
It looks to me like my top piece where it is hinged is a rivet of some sort. Is the whole vent meant to hinge off the third top screw/bolt? (third bit at the top in your picture).
Thanks again.
Mark
Stewy
sa-club
Jeff Stewart
« Reply #3 on: September 06, 2014, 04:06:16 PM »
Hi Mark,
Top hinge is a rivet but should still be on the body.
Cheers Stewy   Cool
