August 06, 2025, 11:26:11 PM *
Author Topic: Smiths Gauges (Again)  (Read 3634 times)
Rod
« on: June 29, 2014, 10:05:30 AM »
Sorry for starting another thread on Smiths Gauges but I can't seem to find the answers through a search.
I am looking to purchase an oil pressure and temp smiths gauge to complement an ammeter that I have. My question is relation to the difference between mechanical and electrical. I am not sure what these gauges are but I am asking what I should look for on the back of them to distinguish between the two. I understand that on the back of the oil gauge there is a thread for the capillary tube to be attached but unsure what I should look for on the temperature gauge. The oil gauge isn't a concern if its mechanical or not as tubes etc can be purchased but I am not too sure about the temp. The temp gauge doesn't come with a sender which is of a concern if it mechanical. A search  brings up electrical senders but not mechanical senders. Is there anyone that can tell me what I should look for on the back of the temp sender to distinguish between electrical and mechanical. If it is mechanical does anyone know where I can purchase the appropriate sender?
On a side note through searching this topic I have found that electrical smith gauges operate at 10 volts and need a voltage regulator. Does this sound right?
Finally can anyone tell me how I should wire up the ammeter?
Rod
KFH
« Reply #1 on: June 29, 2014, 11:08:34 AM »
I have a "mechanical" Smiths temperature gauge.  It has a capillary tube with one end connected to the gauge and the other end has the bulb connected to it which screws into the block.  The tubing is enclosed in a metal protection sleeve similar to a choke cable only more open.  I hope this helps.
« Reply #2 on: June 29, 2014, 12:48:31 PM »
With the correct gauge wire. The wiring to an ammeter has the full current of the vehicle running through it. If the gauge of the wire is too small, it's a short cut to putting the "fire" in "firewall". Make sure that the firewall hole has a good grommet in it, too.
Rod
« Reply #3 on: June 30, 2014, 07:40:20 PM »
Thanks Keith and RET,
RET am I correct in reading between the lines that I should reconsider fitting the ammeter? The gauge I have got didn't include wiring and I was only going to fit it it due to its looks not from a functional point of view.
Rod
newman
« Reply #4 on: July 05, 2014, 03:38:35 PM »
Rod
Do yourself a favour Rod and put the amp meter on your shed's shelf as an ornament and buy a Smiths voltmeter a practical and safe alternative.
Mick
Rod
« Reply #5 on: September 23, 2014, 11:32:09 PM »
Ammeter is on the shelf as Mick and co have suggested.
I have managed to get an oil and temp gauge. Oil is capillary while temp is electrical. Is there anything I can do to check if the temp gauge is funtioning or not prior to fitting it. Ie:are there any bench tests I can do to check if its working or not. Do these things need calibrating or not.
Rod
Page created in 0.019 seconds with 16 queries.
