August 03, 2025, 04:20:45 PM *
Author Topic: Headlight dip switch  (Read 1981 times)
ekute
« on: June 23, 2014, 10:34:04 PM »
Anybody got a spare-got blueslipped with just low beam!
« Reply #1 on: June 24, 2014, 04:35:00 AM »
Check the bottom 3 connections are not loose its pretty common.
If its still buggered pm me and ill send u one.
FATBOY
« Reply #2 on: June 24, 2014, 02:53:01 PM »
Hi Mark ive got plenty at the shed give me a ring i might be going to the shed tonight
regards fatboy
fatboy
0414712441
ekute
« Reply #3 on: June 25, 2014, 06:23:12 PM »
Thanks Pete and Fatboy, I think the headlight switch is the problem but won't get to check it out till the weekend.
ekute
« Reply #4 on: June 30, 2014, 08:34:25 PM »
All is good, isolated the problem to a short in 1 headlight.I first checked the dip switch and all was ok.The light bulb in my thick head finally clicked on when I read the workshop manual which described what happens when you have a short in a headlight!
There is a thermal fuse acting sort of like a relay-it works so quick that I didn't realise what was happening until I really,really concentrated on listening for it.
The bakelight insulator between the spring loaded contacts for the headlght bulb had broken!
Took a couple of hours to fix because I have to remove the wheels to unscrew headlight buckets from the frenched guards.Anyway it allowed me to align the headlights properly as well.
2 birds killed with 1 stone.
Note to self look at workshop manual first.
