April 12, 2025, 11:01:08 AM *
Author Topic: Bolt and screw types n sizes  (Read 5979 times)
« on: March 13, 2014, 10:59:12 PM »
Must be me going pie eyed but I can't bloody find the type n size of the three bolts that go into the Y frame from the gearbox mounts and the screws that go in the top of the rear door  Huh
FCV08
FE FC Club of QLD
« Reply #1 on: March 13, 2014, 11:50:12 PM »
NES
I have used brass machine thread bolts and nuts.
After fitting with the nut on the top side of window frame I cut off flush and file finished.
Dab of Loctite always works well.
Do you want me to send photos?
Craig D
« Reply #2 on: March 14, 2014, 07:05:01 AM »
Top of rear doors 2 self tappers dont they ?
Subframe think their 5/16unf
« Reply #3 on: March 14, 2014, 03:34:51 PM »
All good Craig thanks. Just wanted to know sizes so I could grab em on way home.
gp
« Reply #4 on: March 14, 2014, 04:38:42 PM »
Top of the rear door should have rivets....
« Reply #5 on: March 14, 2014, 04:58:46 PM »
Since the small hollow rivets can be hard to find, this is what I do.
Use the appropriate size pop rivet then take a pin punch and tap through the remains of the steel shaft to remove it.
Then using a countersink punch, tap the bottom of the rivet up neatly.
Failure to do these last 2 steps will result in bailey channel which does not sit in place correctly.
« Reply #6 on: March 14, 2014, 06:18:28 PM »
Good idea! Think I'll try that.
Got the length and size on the gear box mounts?
« Reply #7 on: March 14, 2014, 07:41:29 PM »
I'll measure the ones on mine and let you know.
« Reply #8 on: March 14, 2014, 07:46:56 PM »
3/8 inch fine thread (24 tpi) - 3 and 3/4 inch long - 2 per side including washer and nut
3/8 inch fine thread (24 tpi) - 3/4 inch long - 1 per side and spring washer
« Reply #9 on: March 15, 2014, 08:28:54 AM »
Funny ,Old farts like me can sift through bucket after bucket of spare bolts in the shed and tell you what each bolt is for [all being early holden ] but never stop to think about guys building their cars for the first time not knowing what size bolts go where .Probably because I rarely buy them new [tight ass]. Its only when it comes to mods. or hot rod projects I have to think about it . Haydn
« Reply #10 on: March 15, 2014, 05:03:12 PM »
Well its not my first build although being somewhat younger it is odd to my mates that I work mostly in Imperial (including at work). I do lack the hoard of bolts that you talk about Hayden  Tongue
« Reply #11 on: March 15, 2014, 05:10:10 PM »
I have plenty of bolts sorted and stored here. Make a list of what you need and I should be able to supply it.
Page created in 3.265 seconds with 20 queries.
