September 09, 2025, 03:53:04 PM *
Author Topic: Weber Carby problems  (Read 3515 times)
griffo
« on: February 24, 2014, 07:59:00 PM »
Hi
My car starts and runs for a short time then just cuts out , it feels like its starving for fuel !! I leave it sit for awhile
and it then does the same thing
any ideas,
Griffo.
« Reply #1 on: February 24, 2014, 08:38:46 PM »
Fuel pumps shagged or blocked jet  maybe take the filler cap off to make sure shes breathing  Huh
griffo
« Reply #2 on: February 24, 2014, 10:03:33 PM »
Thanks FCRB26
I tested the fuel pump ( undid the fuel line and started the car - fuel came out) after that I removed the jets one either side of the carby and they were OK ,
Should I remove the jets inside the carb and test ??
Griffo
« Reply #3 on: February 25, 2014, 09:02:44 AM »
Is fuel getting to the bowl properly . The start and stop sounds like a needle and seat problem or a float level problem . More like a needle and seat because it eventually refills the bowl enough to start. Haydn
colt
act-club
« Reply #4 on: February 25, 2014, 07:07:55 PM »
Check that your fuel pick up isn't blocked.
colt
griffo
« Reply #5 on: February 26, 2014, 06:12:22 PM »
Thanks for the replies
I had a good look to try and find out whats going on
And Colt I reckon you've hit  it on the head, ( Ive got some gunk in the fuel tank )
I undid the fuel line just before the filter that's before the fuel pump and stuck my air gun up the
fuel line and blew the @#$& out of it.
Problem fixed.   for a little while any way,
so now I'll remove the fuel tank and clean it out.
Thanks for the help
Griffo
