August 21, 2025, 03:02:33 PM *
Author Topic: Replacing Pinion Seal  (Read 1435 times)
Rod
« on: December 31, 2013, 06:49:08 PM »
Hi All,
Firstly compliments of the season to you all. With holidays upon us, I have decided to do those little jobs on my old ute that never get done. One is changing the diff centre due to a whine. I have had two 3.55's in the diff, both having whines. The one I have got in now had new bearings etc... put in it but it still had a whine (I think the crown and pinion were / are worn).
Anyway I have finally sourced another one but want to change the seal before putting it in. The gregory's manual is good as it gives a different description. A I read it a stock FC seal is easy to change. All your need to do is torque it up to 120lb(I think) where it seems a little more complicated for a later model centre. It talks about pinion load, lash etc... All a little confusing. Would I be safe if I mark the yoke and nut and when doing back up make sure that these two line up?
Should there be much lash between the pinion and crown as this one seems to have a little play. Don't want to put this one in and go through the same issues.
Rod
