mickrat
« on: October 16, 2013, 01:55:53 AM » |
Here is a picture of the car I started out with. Came from Victoria. Bought it on a whim. Been looking for one for quite a while. Looked ok at first. Amazing what some bog sticky silver tape and tar can conseal.  Sent from my HTC One XL using Tapatalk now Free
1957 fe special sedan (rusty one ) 1958 business sedan ( good one )
mickrat
« Reply #1 on: October 16, 2013, 02:14:52 AM » |
« Last Edit: October 16, 2013, 01:52:30 PM by stinky »
mickrat
« Reply #2 on: October 16, 2013, 02:34:07 AM » |
mickrat
« Reply #3 on: October 16, 2013, 02:43:26 AM » |
been workin on her for about 10 months now. Starting to see the light and the tunnel thing.    Sent from my HTC One XL using Tapatalk now Free
mickrat
« Reply #4 on: October 16, 2013, 04:51:57 AM » |
the only parts i ended up useing from this car were the front subframe front and back windscreens dash and glove box , pedel box and the seats original bench, but ive dismantled the front seat and it has many broken springs so it looks like she will go too, what ya see is not wot ya get !!!!!
« Reply #5 on: October 16, 2013, 05:15:08 PM » |
looking good so far, ar they the original engine pipes from the headers?. Ineed to get a set made for mine but haven't been able to find a photo of them. Regards Jim
mickrat
« Reply #6 on: October 16, 2013, 06:41:48 PM » |
the engine pipes were already on the headers when I purchases them. I will run them for the meantime as they came with a complete near new exhaust system. If I was starting from scratch I would have made two separate pipes at least to the muffler. Here is a picture of the pipes before I wrapped them.  Sent from my HTC One XL using Tapatalk now Free
« Reply #7 on: October 16, 2013, 09:51:41 PM » |
Similar set up as mine, although I have made a single air cleaner using a Dato 180B SSS oval filter. I was also thinking of doing twin pipes, but not sure of they would clear the idler arm on full lock. Something to look into when I get the front end back together. Thanks, Jim
fink
« Reply #8 on: October 17, 2013, 11:12:44 AM » |
Nice work fix'n that rust,keep at it!
mickrat
« Reply #9 on: October 22, 2013, 01:45:47 PM » |
Brakes all fitted waiting on wheel so I can get it to rolling stage    Sent from my HTC One XL using Tapatalk now Free
« Reply #10 on: October 22, 2013, 02:28:52 PM » |
G'day Mickrat, Your rear brake shoes are on back to front  ACE
mickrat
« Reply #11 on: October 22, 2013, 02:34:28 PM » |
Thanks for pointing out my mistake. Probably saved me from dramas down the track. Maybe auto sparkys shouldn't play with brakes. Guy who bonded them for me marked them F and R.
mickrat
« Reply #12 on: October 22, 2013, 03:16:53 PM » |
Just checked brakes on the left . shoes round the right way on the right put the shoe marked R on the front. Probably because I assembled them together on the floor .not realizing when it goes on the other side it's on the opposite side. Thanks again Sent from my HTC One XL using Tapatalk now Free
mickrat
« Reply #13 on: October 22, 2013, 03:54:52 PM » |
Her are some numbers for ken. Front subframe. 6_7794M  Sent from my HTC One XL using Tapatalk now Free
brett_f
Offline
« Reply #14 on: October 22, 2013, 04:49:36 PM » |
Looking good mate. Brett
« Reply #15 on: October 22, 2013, 05:49:10 PM » |
Thanks for that, Lockhart cream is a very rare colour. The only time I have it recorded is on single colour FE special sedans made in 1956.
FCV08
Offline
FE FC Club of QLD
« Reply #16 on: October 22, 2013, 09:47:09 PM » |
Mickrat
Coming together nice.
Just for you info, if you run into trouble with the top ball joint hitting the rim, fit a WB one as ther are a sealed unit and sit much lower.
Keep those posts coming
Cheers Craig D
mickrat
« Reply #17 on: October 31, 2013, 08:14:46 PM » |
All suspension fitted brake lines and fuel lines in and on four wheels. Was going to shorten steering column. But have decided to fit an ek unit complete. Looks like it will fit. Shorter. And like the look of the gear lever. Body work next fit doors and guards for alignment    Sent from my HTC One XL using Tapatalk now Free
Old_Mt_Isa_Boy
Offline
My Ute
« Reply #18 on: November 01, 2013, 10:56:58 PM » |
Nice to see it on all fours . Looks special Mickrat.
Wayne b
« Reply #19 on: November 02, 2013, 09:32:45 AM » |
I do recall a long time ago ,I modified a fc gear stick to fit in the ek selector tube . Try the crowd that do the 3 speed all sincro conversions .I did it by cutting off both sticks and swapping them but removing the selector tubes and changing the tops is better.I still use the ek column length on my fc-commo collapsible .Just thought I would put that out there. Regards haydn
