August 28, 2025, 01:41:20 PM *
Author Topic: Head-lining installation  (Read 3069 times)
sgo
« on: October 10, 2013, 09:04:41 AM »
I've heard of trimmers using hair-dryers or heat when installing head-linings.
Just curious about why and where this is used and to what effect?
Perhaps a question for Stinky Huh
« Reply #1 on: October 10, 2013, 12:55:18 PM »
I use a heat gun at the very end of the job to get rid or persistent wrinkles, it's not really required as the wrinkles generally come out after a day in the sun.
The heat allows the vinyl to stretch that little bit extra, you are after all installing what was a flat piece of vinyl into a curve.
Really deep creases need to be removed by adjusting the rooflining rather than heat though.
I always recommend people use a hairdryer and regularly touch the heated vinyl with the back of their hand to make it doesn't get too hot.
sgo
« Reply #2 on: October 10, 2013, 08:07:25 PM »
Thanks, makes sense.
Rod
« Reply #3 on: October 10, 2013, 10:03:18 PM »
Please excuse me if this doesn't work. First time using tapatalk. Stinky I hope you can give some feedback on the attached photo. In my ute the headlining is coming away him one corner. I need to take the window out to replace the rubber due to leaking and was hoping to do something with the headlining. Many years ago l used your method of a heat gun with some success but it is coming away again. I am a little concerned it is pulling away too much. Can suggest a contact adhesive / glue to use and how to safely adhere the lining to the window frame?
One other thing I was thinking of doing was to take a piece of lining which is behind the panel that runs up the side of the front window and holds the windlace in place and stick it somehow to cover the section which is pulling away.
Have you got any thought?
Thanks in anticipation. Rod
Sent from my GT-N8010 using Tapatalk now Free
« Reply #4 on: October 11, 2013, 12:25:02 AM »
If you are replacing the rubber and have access to the rear of the roof lining, get some contact adhesive. You can use the spray can stuff or the brush on gear or if you have a friendly trimmer he might sell you some to brush on. A scrap of vinyl glued back-to-back should fix the tear and be mostly inconspicuous if you are patient and careful, always wait for the glue to tack well ie feels like sticky tape, before pressing the backings together. Let it dry for a day or two before any pulling or stretching.
