ekdave
Offline
www.offyarocker promotions.com
« on: July 22, 2013, 06:59:45 PM » |
Anyone got a spare gemini booster from a conversion They are not going ahead with ? Cheers Dave
« Reply #1 on: July 22, 2013, 07:21:19 PM » |
There about as hard as 200B ones to find at the moment... Good luck ill ask bloke up the road with geminis.
« Reply #2 on: July 22, 2013, 07:57:52 PM » |
Current Rides: 1958 "Black and White Taxi" FC special Sedan, 1957 FE special Sedan, BA Futura, 2015 VF Commodore, 1956 Austin Tipper Truck
« Reply #3 on: July 22, 2013, 07:59:48 PM » |
bonnet in good condition $80 guards in good condition abit of surface rust but nothing bad $70 each doors all rust free $80 each headlights x3 in good condition $100 a pair taillights x2 in good condition $100 a pair centre console auto $30 gemini hand brake setup cable and handbrake and brackets $70 td tg bars x2 in good condition $120 a pair petrol tank in good condition $60 gemini windows back and front in good condition $80 each gemini seats out of slx with matching door trims in green/blue $300 booster in mint condition with xb master $150 side mirrors that control them from your door trim x3 $100 for all three. few more parts i have
0478153495
« Reply #4 on: July 22, 2013, 08:13:53 PM » |
fink
« Reply #5 on: July 22, 2013, 08:18:04 PM » |
Was there today.my old stomp'n ground!
« Reply #6 on: July 22, 2013, 08:22:13 PM » |
« Reply #7 on: July 22, 2013, 08:31:46 PM » |
Thats what my sedan has. $220 from summit
The cheap arse booster fits the wilwood cylinder
Crumpsnr
Offline
Shellharbour NSW
« Reply #8 on: July 22, 2013, 08:52:27 PM » |
What cheap arse booster would that be Pete? Ta, Martyn
« Reply #9 on: July 22, 2013, 08:59:42 PM » |
« Reply #10 on: July 23, 2013, 05:39:22 AM » |
The ebay one at the top of the page bolted up to the wilwood one
« Reply #11 on: July 23, 2013, 09:11:55 AM » |
On the subject of boosters...
how can you tell a double diaphragm booster from a single.. physical size?
I'm leaning toward using an OEM booster versus a cheap ebay one, as I read the ebay ones are not rebuildable.. is there truth to this?
Pete I think Datsport sells the 200B boosters. I've got a 1200 booster at home and they are tiny little things, I think they are similar to the 200B. Would that provide enough boost?
« Reply #12 on: July 23, 2013, 10:29:55 AM » |
A 200 is a fair bit bigger than a 1000 and a 180B is different again and i was running a 200B on the sedan and wasnt overlly happy with it im going to check it right out before i use it as the ute has a bit more poke than the sedan use too.
Pete
Offline
« Reply #13 on: July 23, 2013, 12:22:36 PM » |
Pete
Think from memory the Gemini booster has about 860 lbs of force only good for a light weight car ......FC427.......
ekdave
Offline
« Reply #14 on: July 23, 2013, 06:43:44 PM » |
Thanks guys
Was going to run the gemini booster and commodore Master
4 wheel commodore discs
Thought the gemini booster was the norm for this set up ?
Cheers Dave
Crumpsnr
Offline
Shellharbour NSW
« Reply #15 on: July 23, 2013, 06:47:07 PM » |
Thanks Pete
