July 13, 2025, 05:37:20 AM *
Pages: 1 [2] 3 4 5   Go Down
Author Topic: RE Catalouge of FE FC parts  (Read 87028 times)
« Reply #20 on: November 06, 2013, 07:48:39 AM »
So far so good
Just need to fit to a grille tonight.
Crumpsnr
Shellharbour NSW
« Reply #21 on: November 06, 2013, 04:39:46 PM »
+2
Fit it to mine, fit it to mine!!   Grin Grin Grin
« Reply #22 on: November 06, 2013, 06:41:20 PM »
Fitted up today very happy .
Ill post tommorow keith
KFH
« Reply #23 on: November 06, 2013, 06:54:45 PM »
Thanks Pete look forward to fitting it to my badge.  PM me the cost.
KFH
« Reply #24 on: November 11, 2013, 07:16:21 PM »
Well Pete has done his magic again.  The grill badge bracket arrived today.  The quality is excellent and will never rust as it is made of stainless steel. Very happy with the bracket.  Thanks Pete.
« Reply #25 on: November 12, 2013, 05:01:53 AM »
Thanks Keith.
I reckon the badges just finish a resto off cant wait to see it fitted.
As i i said to Keith my badge was fitted with the 2 small angle clips to retain the badge as the original tiny pins were broken they may need a tickle as im sure the thickness varies for the badges this was a good length for mine so should work fine.
FCV08
FE FC Club of QLD
« Reply #26 on: November 12, 2013, 11:30:07 PM »
Anymore on the production line? Grin Grin Grin
I made some of my own but the finish on your look fantastic.
Craig D
« Reply #27 on: November 13, 2013, 06:38:55 AM »
Yep I can make some more
once their programmed their on file.
FCV08
FE FC Club of QLD
« Reply #28 on: November 13, 2013, 09:38:25 PM »
PM me the costs including postage.
Craig
« Reply #29 on: May 09, 2014, 06:25:52 PM »
 I have reccesed brake booster mounts in stock
I had a metal spinner make 20 of
They are 190mm inside 80mm deep
« Last Edit: May 09, 2014, 06:36:30 PM by FCRB26 » Logged
FCV08
FE FC Club of QLD
« Reply #30 on: May 09, 2014, 06:51:00 PM »
Have you had a crack at anymore clock mounts?
Craig D
« Reply #31 on: May 09, 2014, 07:54:50 PM »
yep i have 10 on my bench i went to fold in a larger V block and they pull into the access holes making the fold un square.
So im going to try it on monday with a piece of colourbond under it hoping it doesnt pull into the hole.
Will let you know monday.
FCV08
FE FC Club of QLD
« Reply #32 on: May 09, 2014, 08:28:13 PM »
Thanks Pete
« Reply #33 on: May 10, 2014, 08:29:21 AM »
Speaker recess too maybe??
« Reply #34 on: May 10, 2014, 08:47:38 AM »
Pete , have you ever taken a look at the lower tailgate internal mechanism . Just because they seem to wear at the slots where the wires go on and have been told they are difficult to repair . Cheers Haydn
Ole
« Reply #35 on: May 10, 2014, 10:06:50 AM »
How much are you asking for the booster recesses Pete? I am definitely interested in one.
Cheers Ole
Adelaide SA
« Reply #36 on: May 11, 2014, 07:52:54 AM »
I have repaired a few for people if anyone is stuck msg me.
Cheers Ole
$50 each plus delivery
I can do the weld in speaker recceses as well would just need to confirm the dimensions of your speakers..
« Reply #37 on: May 15, 2014, 07:41:48 PM »
A new one today what a mission to get the fold sequence right 1st go tho came up awesome
Hr engine mounts for firekraka and v6 conversion mounts
 I machined and fitted heavy wall crush tubes then bead blasted them.
FCV08
FE FC Club of QLD
« Reply #38 on: May 15, 2014, 09:07:33 PM »
Exceptional work again Pete  Wink Wink
Well done
Maco
« Reply #39 on: May 15, 2014, 09:11:40 PM »
Nice work Pete!
Better in Green
Pages: 1 [2] 3 4 5   Go Up
