September 09, 2025, 01:57:47 AM *
Author Topic: Guard Seal  (Read 4436 times)
ekute
« on: May 27, 2013, 05:59:09 PM »
What do people use for the seal between guards and inner guards?
fink
« Reply #1 on: May 27, 2013, 08:39:40 PM »
Pretty sure you can use a windscreen sealer as it's similar,it doesn't set hard but bonds and seals even with a slight movement,understand?good!anytime,thanks Gaz! Grin
« Reply #2 on: May 27, 2013, 10:23:24 PM »
You can use a product called "uncured rubber", it comes in different sizes & thicknesses I would use .5 or 1mm thick, Clarke rubber stores sell it.
Regards Jim
« Reply #3 on: May 28, 2013, 09:50:29 PM »
As long as ya rubber don't break,  :othen u end up waking at 5am and cutting sick like hoon lol..all sorts if trouble.
« Reply #4 on: May 29, 2013, 05:37:25 AM »
5am  Huh been out the shed since 3.30 left at 4 start at 5.
To get back on the subject I used sikaflex and it was horrible will use wurth windscreen urethane this time round.
« Reply #5 on: May 29, 2013, 07:51:21 PM »
Noted Cool
ekute
« Reply #6 on: May 29, 2013, 08:55:45 PM »
Wouldn't the windscreen urethane bond too hard?
« Reply #7 on: May 29, 2013, 09:13:53 PM »
G'day Mark,
I used some rubber "U" channel from Clark Rubber.
Punched holes for guard bolts with a wad punch.
ACE  Cool
ekute
« Reply #8 on: May 29, 2013, 09:37:03 PM »
Thanks for the help guys. When I pulled my car apart the sealer looked like rubber but the upper rear most section was more like a sort of foam rubber and seemed to be thicker.
Have we all used the same product for the whole length?
I didn't use anything on a previous fc and ek! All that seemed to happen was that a bit extra crap got in the engine bay from driving in the wet.
fink
« Reply #9 on: May 31, 2013, 07:27:57 AM »
You could also use the ''tar like'' flashing that roof plumbers use.You can cut this in strips,no mess at all,then you peel the paper off one side and stick it to your s/frame and door pillars and cut your holes out.You can double up  and make it even thicker.This stuff doesn't go hard,it seals100%. Wink Gaz!
« Reply #10 on: June 01, 2013, 06:34:57 PM »
thanks fink
ekute
« Reply #11 on: June 02, 2013, 06:17:55 PM »
Hey I've got some of that stuff Fink.Sounds good!
