August 13, 2025, 01:10:46 PM *
Author Topic: Vic FE-FC Club Annual Auction Day  (Read 2866 times)
FCwagon
« on: May 28, 2003, 09:40:06 AM »
Sorry about the duplication of this topic everyone, but I haven't quite figured how to update the list in the original post. Perhaps RET you might be good enough to help me out next time.
Anyway, there's a few more items added to the list and I've now started adding the numbers which should carry through to the final list.
cheers,
Leigh
Red & white is alright
« Reply #1 on: May 28, 2003, 11:23:44 PM »
Leigh,
1) Make a copy of the auction list on your PC called something like "Vic_Auction_YYYY-MM-DD.xls" where YYYY-MM-DD is the date.  (Today would be 2003-05-28.  You don't have to format the dates in this - technically called "ISO" format - but they always sort correctly in a folder listing, whereas putting them in English format "d/m/yy" never does.  It also means you have a backup if you accidentally bugger up the original file.)
2) Reply to the original thread including this file as an attachment.
3) When the thread is refreshed with the new post on the bottom, delete the older post that had the list attached (which will also delete the attachment that went with it).
The trick here is to avoid putting any important text on the post that has the attachment, since it will be deleted.  If you have general info about the auction, post it in a separate reply to any that have the auction list attached.
Hope that's clear as mud Wink
FCwagon
« Reply #2 on: May 30, 2003, 09:34:54 AM »
Thanks RET,
I'll give it a try next update
Leigh
Page created in 0.021 seconds with 17 queries.
