August 05, 2025, 01:20:09 PM *
Author Topic: Temperature Sender  (Read 2669 times)
Rod
« on: May 18, 2013, 11:15:21 AM »
Hi All, I have had a look around and can't find the answer specifically. I have three temp senders in my posession. One is a 217°F ,one is a a 226 F, while the last one is a 239F. I need to replace a faulty one. Which one should i use? Is a standard grey running a 7lb radiator cap.
Stewy
sa-club
Jeff Stewart
« Reply #1 on: May 18, 2013, 01:32:53 PM »
Hi Rod,
The manual section 12F says
"Tell Tale" Assembly-
Temperature, Glows when    ..   ..  ..  Engine Temperature reaches 217 degrees F. + - 5 degrees F.
Cheers Stewy   Cool
« Reply #2 on: May 18, 2013, 04:59:49 PM »
The 217 F switch is fitted to fx - FE up to eng L388857 which had the 4 lb cap. When the 7 lb cap was fitted the switch changed to the 226 F one.
Rod
« Reply #3 on: May 19, 2013, 01:58:50 PM »
Thanks Stewy and Ken,
After viewing your post Stwey I looked at the manual and it confirmed what Ken said. Based on this I guess there wouldn't be a problem using a 217F. It would just mean the idiot light would come on earlier. Given that greys should run at about 180F would my assumption be sound?
Thanks again fella's.
Rod
