August 06, 2025, 11:32:48 AM *
Author Topic: HQ or Torana stub axles  (Read 12468 times)
GMB-58FC
Stage one complete...
« on: May 09, 2013, 01:38:51 PM »
I'm chasing a set of HQ or Torana stub axles and bottom sub frame bolts so I can get this car up and rolling.
Happy to pay freight and would prefer complete units ready to bolt up.
Ben
ABS Hobart- 6231 5855
PM FOR QUOTE
GMB-58FC
« Reply #1 on: May 09, 2013, 01:52:55 PM »
Sorry I should have said LH or LX Torana not LC/LC ones to suit HR disc front end.
PM FOR QUOTE
GMB-58FC
« Reply #2 on: May 13, 2013, 08:41:10 PM »
Anything out there or do I have to save up and get new ones???
PM FOR QUOTE
« Reply #3 on: May 13, 2013, 08:52:03 PM »
Where r u ?
I have hq and lc lj ?
Pete
GMB-58FC
« Reply #4 on: May 13, 2013, 09:17:30 PM »
Where r u ?
Pete
I'm in Tassie Pete, how much?
Do people use LC/LJ on HR front ends or only on the Torana front ends due to the steering geometry difference???
PM FOR QUOTE
brett_f
« Reply #5 on: May 13, 2013, 09:42:38 PM »
Ben, What stud pattern are you running. I have Torana stubbs with commodore disc's and calipers. Not cheap mate as they were made/modified by castle main rod shop. Just putting it out there mate in case you get stuck. brett
GMB-58FC
« Reply #6 on: May 14, 2013, 06:45:54 AM »
Haven't settled on a stud pattern as yet Brett as it was dependent on what axles I could source first (kinda the arse about way of doing it I know) currently the car has a HR disc brake front end and HR drum rear.
The plan was to keep it like this to get it mobile whilst doing the body work then go from there.
PM FOR QUOTE
« Reply #7 on: May 14, 2013, 07:53:26 AM »
Ben theres no gain here until you work out what sorta motor your gunna run.
Torana and HR and HK HT HG HQ HJ ect all interchange but if you run a healthy V8 i suggest commodore or HQ so torana wont help you at all they have little to no gain over HR.
You can bolt up a set off a  HQ stubs and all but will need to change diff stud pattern?
I do commodore conversion onto HR drum stubs but a diff will need to be narrowed to suit ?
GMB-58FC
« Reply #8 on: May 14, 2013, 10:22:41 PM »
Will be running a Holden 6 in this one Pete Wink
PM FOR QUOTE
FCV08
FE FC Club of QLD
« Reply #9 on: May 15, 2013, 09:59:46 PM »
Ben
Following on from Pete's comment, I am running a full VN V8 Commodore brake system.
Although the rear diff can be shortened, to suit wheel track, the VN front rotors on a HR Drum Brake Stub with adapters, will need a different offset rim to keep in spec.
HQ-HZ rotors are about 20mm narrower than VN. If you are runnig these stubs no need to any adapter plates either.
My wheels are 15x7 with the rear having a 3.50 BS and the fronts having a 4.50 BS
Hope this helps
Craig D
« Reply #10 on: June 11, 2013, 07:28:45 PM »
Hey white FC, finally found this thread again  Cheesy Ummm, I plan on running hq front brakes but i have just converted and shortened a 28 spline vl turbo diff at rear, so my question is how did u get the hq pattern at the back. Did u modify the rear axle hub or is there another way?
« Reply #11 on: June 11, 2013, 10:30:27 PM »
You can  buy blank HQ rotors and get them drilled to 120mm PCD to match the Commodore rear ......FC427........
« Reply #12 on: June 11, 2013, 10:51:32 PM »
any brand recommended?
« Reply #13 on: June 11, 2013, 11:06:19 PM »
DBA014US [ T3 Slotted blank ]  OR    DBA014UX [ X/Drilled Slot blank ] Checked last week for a job I'm doing both in stock at DBA Silverwater  get your local brake shop or parts shop  to order as they don't sell direct to public .....FC427.......
waynos
patience grasshopper
« Reply #14 on: June 11, 2013, 11:46:12 PM »
fc 427,
do you use b&r brakes at blacktown?
i have found the bloke there quite patient to my dumb questions,
and cheapest around.....
i highly recommend them to anyone in sydney.
i think he quoted me 66 bucks for a hq rotor
waynos
« Reply #15 on: June 11, 2013, 11:48:02 PM »
sorry to hijack this thread but isnt the difference of hq and commo .6 of a mill?HuhHuh?
waynos
« Reply #16 on: June 11, 2013, 11:53:45 PM »
also lh lx torry dont really work,i have them and had to shorten top wishbone by half an inch to get proper camber
« Reply #17 on: June 12, 2013, 09:00:04 AM »
Torana has a different incline angle on the stub axle  2  or 3 deg from memory  just use HQ -WB .......FC427.......
« Reply #18 on: June 12, 2013, 09:03:55 AM »
fc 427,
Yes I have used  Michael at B&R Brakes for the last 25 years before that I used his dad always good   Grin Grin Grin Grin........FC427......
« Reply #19 on: June 12, 2013, 10:34:48 AM »
Actually I believe that only hg ht are any good as hq short arms dont give u right toe out on turns either cos they have no bend.
