August 05, 2025, 10:48:32 AM *
Author Topic: Body-S/F ID  (Read 5649 times)
fink
« on: May 06, 2013, 07:45:19 AM »
Recently i aquired my 1st FE,a van,the body ID tells me it's a Melb car and the s/frame tells me it's SA.Am i right in thinking they just used what they had at the time because it looks orig where it's joined at the f/wall,thanks Gaz! Huh
« Reply #1 on: May 06, 2013, 05:45:20 PM »
Would be unusual if it is original, most of the time the slack was taken up by SA plant for FE, so a lot of Melbourne assembled cars had the body made in SA.  Not the other way round.
fink
« Reply #2 on: May 06, 2013, 08:30:48 PM »
Cheers Ken ! Kiss
brett_f
« Reply #3 on: May 06, 2013, 08:54:41 PM »
Gaz, I think you have a cut and shut Grin Grin Grin
Brett
fink
« Reply #4 on: May 08, 2013, 06:02:32 PM »
Well it doesn't happen very often,but i screwed up,Ken you were spot on,just got the car home and found everything opposite,so here goes.
FE-2104-3032-A
TRIM-157-684
PAINT-256-7471
RPO-333
Can you tell the prod date from this,colour looks ,green with green trim,thanks,Gaz!
Stewy
sa-club
Jeff Stewart
« Reply #5 on: May 08, 2013, 10:26:23 PM »
Hi Gaz,
Ocean Mist Green paint with a "cool green" interior trim.
RPO 333 means that the tailgate window factory fitted.
Ken may be able to give you a rough date via the production number but the original engine number is the more accurate.
Cheers Stewy   Cool
fink
« Reply #6 on: May 09, 2013, 08:01:38 AM »
Thanks Stewy,i posted the nmbrs for Ken,i'm just curious on the build date, Gaz!
« Reply #7 on: May 10, 2013, 07:54:04 PM »
FE vans and wagons were only manufactured in Adelaide, so there's only one sequence of numbers. That makes guess-timating a build date from them a little easier. Ken's the guru on that front.
Only the Elizabeth plant had a press big enough to make the roof panel; Fishermans Bend got one late in 1959, so there are a few FC wagons made there, but not many.
Hope that helps.
cheers RET
Stewy
sa-club
Jeff Stewart
« Reply #8 on: May 10, 2013, 08:40:08 PM »
Hi RET, interesting info there, only I think you mean the Woodville plant because Elizabeth did not come on line until 1962
Cheers Stewy   Cool
« Reply #9 on: May 11, 2013, 12:05:29 AM »
Yes, you know whenever I say Elizabeth I mean Woodville...
« Reply #10 on: May 11, 2013, 01:52:49 PM »
For accurate dating I need the chassis number please
Regards. Ken
fink
« Reply #11 on: May 17, 2013, 06:53:15 PM »
No problem Ken,here goes-737911M,thanks Gaz! Grin
« Reply #12 on: May 19, 2013, 04:00:17 PM »
Gaz, production date from my database is second / third week of November 1957. Around about the tenth.
fink
« Reply #13 on: May 19, 2013, 08:15:47 PM »
Thanks Ken Smiley
