August 09, 2025, 02:45:12 AM *
Pages: [1] 2   Go Down
Author Topic: Larger offset wiper piece  (Read 10694 times)
« on: April 17, 2013, 10:59:50 AM »
Need this piece but the larger offset version...
« Reply #1 on: April 17, 2013, 11:08:30 AM »
why not cut and shut it  Huh Huh Huh.......FC427.........
« Reply #2 on: April 17, 2013, 12:10:52 PM »
Or drill out with a countersink bit so it fits.
Billy Blackarrow
« Reply #3 on: April 17, 2013, 01:35:28 PM »
Check out bret_f's Commodore Wiper Conversion he cut & shunt his
  BILLY BLACKARROW
BILLY BLACKARROW
« Reply #4 on: April 17, 2013, 04:18:55 PM »
I though there was two versions of this piece and was hoping to get the longer one rather than modify...
brett_f
« Reply #5 on: April 17, 2013, 04:40:04 PM »
Nes, I believe the only way is to modify mate. Not a hard job for someone like you. A couple of beers a couple more and then done. Regards Brett
« Reply #6 on: April 17, 2013, 04:45:52 PM »
There are 2 versions but you will be unlikely to find just the bracket by itself unless you bought another complete wiper motor.  You can easily modify by cutting and joining in a piece. Make sure the distance between the holes is maintained or just less than. Definitely not more than the length or wiper overrun will result.
« Reply #7 on: April 17, 2013, 04:53:10 PM »
Thanks Ken. Awesome grinder skills GO!
« Reply #8 on: April 17, 2013, 05:53:39 PM »
Ahuh your the grinder man now ..
measure once cut twice hang on that dont sound right.  LOL
 i can make some new ones up if anyones intrested ?
« Reply #9 on: April 17, 2013, 07:25:01 PM »
I love you Petey....
Need my template?
JOX515
« Reply #10 on: April 17, 2013, 08:23:51 PM »
I would be interested if you made any up Pete.  My grinding skills are at least equal to NES's lol  Wink  Cheers, Graeme
« Reply #11 on: April 17, 2013, 09:14:57 PM »
ill have a look in the morning  see what i come up with..
« Reply #12 on: April 17, 2013, 09:19:03 PM »
bahahahahaha Cry
FCV08
FE FC Club of QLD
« Reply #13 on: April 18, 2013, 10:24:46 PM »
Nes
I modded mine but would certainly interested if Pete knocked up a few.
Craig D
« Reply #14 on: April 19, 2013, 04:07:43 AM »
Made 2 yestetday they look good but wanting to do it properlly im waiting on a tapered ream to do the hole for the motor..
Supplier said earlly next week.
Ill post a pic this afternoon.
« Reply #15 on: May 02, 2013, 07:00:36 AM »
I made a few trial runs in the 5 min i had and they are ok not real happy with them.
You cannot fold a deep enought offset and being m8 the nut hits the fold line. Also mine is reamed to much so sits lower. It was a 5min muck around.
And you cant make it longer or it puts your throws out..
So i want to check out which way it rotates as the pic that came up on crumpsters  pics shows that a spacer is needed so i thought of doing a small flatbar with the slot cut and having a boss tapped m8 with the taper reamed into it so it simply screws on. But which way it rotates determines weather it will unscrew or not.
I hope i havent confused people as i often confuse myself.
Heres the one i did.
Crumpsnr
Shellharbour NSW
« Reply #16 on: May 02, 2013, 09:47:02 AM »
I'll have a look tonight NES. I'll also post a pic of the arm I'm using. It's a combination of the Commodore arm where it fits to the motor, plus the end of the arm that was on the existing wiper motor when I got the car.
Crumpsnr
Shellharbour NSW
« Reply #17 on: May 02, 2013, 09:49:26 AM »
Oops, not NES!  Cheesy Nice work too.
Crumpsnr
Shellharbour NSW
« Reply #18 on: May 02, 2013, 07:44:58 PM »
Hi FCR, here are pics of my modified arm. The Commodore arm bent quite easily and left room for the original nut. I cut the Commodore linkage end off and tacked on the end of the EK arm. It had already been chopped about by the previous owner. Now I know it works I'll weld it fully.
Unsure about rotation direction. Will rewire the motor tomorrow night and report back if no-one else can reply before then. Regards, Martyn
[/URL]
[/URL]
FCV08
FE FC Club of QLD
« Reply #19 on: May 02, 2013, 07:56:33 PM »
Could you knock them up with the waterjet.
You could cut them out of 15mm plate steel/alloy using the side profile to get all the offsets and not have to worry about the folds and get an exact right angle. Then drill the holes etc.
Craig D
Pages: [1] 2   Go Up
Page created in 0.022 seconds with 18 queries.
