April 11, 2025, 09:34:53 AM *
Pages: 1 ... 20 21 [22] 23 24 ... 48   Go Down
Author Topic: FC Ute  (Read 538064 times)
« Reply #420 on: June 20, 2014, 07:38:10 PM »
Worth the wait on the wheels Pete, even with all the pissing around you're enduring.
« Reply #421 on: June 20, 2014, 07:46:24 PM »
I think with a small centre cap in 17inch they will be real subtle should look nice. (hopefully)
« Reply #422 on: June 20, 2014, 09:09:47 PM »
Along with every other aspect of your project; clean looks achieved through precision engineering.
Looking forward to the next update.
« Reply #423 on: June 23, 2014, 07:17:21 PM »
Todays project well it took me 5min to draw slight stuff up so I have to modify it a bit but I knocked up a pedal box.
I machined the bushes from brass and cut the pedal arm from 6mm mild
Hopefully I get it done tomorrow and I can sell it as a kit.
« Reply #424 on: June 24, 2014, 10:12:38 AM »
Nice work as usual Pete.
I like how you have the tabs that slot together to help retain the shape as you weld.
what length arm and pedal ratio did you end up with?
« Reply #425 on: June 24, 2014, 11:25:46 AM »
Well that didnt work
So I re did another at 5am.
The tab with the m6 button head will be the 3/4 pin and the pedal will have tube welded into the end and ill run brass bushes.
I copied a vs commodore for ratio ed.
And I got lazy with the tabs on this one .
I put tabs on the firewall piece and plug welded thru them.
« Reply #426 on: June 24, 2014, 11:49:06 AM »
« Reply #427 on: June 25, 2014, 06:56:55 PM »
Was in a hurry today so not many pics
I finished the pedal box
Machined a tube and welded to the top of the pedal arm
Machined brass bushes pressed them into the pedal arm .
Then machined a 3/4 pin and welded the lock tab on .
It fits perfect really happy with it feels really solid.
ekute
« Reply #428 on: June 25, 2014, 08:12:40 PM »
Wow nice work Pete!
« Reply #429 on: June 25, 2014, 10:04:36 PM »
awesome stuff, I would love to learn AutoCAD
ps VT is a bolt straight unit as JB will also support (for others) unless you have a recessed booster like Pete (and you get the double diaphragm booster 4:1 and quick refill master for twin piston callipers).
« Reply #430 on: July 06, 2014, 09:06:23 PM »
Keep on chugging.
Got the pedal box finished.
I wasnt happy how the front cover  latch assembly finished with a raw edge so i shrunk everywhere where it was "puckered" and extended it 15mm the i cut it so it has a 15mm offset arc then welded a 5mm round bar to the edge and smoothed it in.
So front end and all the grille shed ect are going to blaster tuesday then off to paint.
I have been putting off the tunnel stiffener as it was going to be a bastard of a job so i cut 15mm strips and used the shrinker and stretcher to get the arc perfect then i welded them in and welded a strip in the centre of it . took some marking out as its tapered 2 ways.
« Reply #431 on: July 06, 2014, 10:26:47 PM »
I'll bet that was the end of Sunday. Nice results.
« Reply #432 on: July 07, 2014, 05:34:28 PM »
Finally found my chassis number its very very faint
Its saying my cars an FE ? Could it of had a different subframe fitted ?
But the grille assembly is really earlly FC it has chrome over steel slats ?
ID Plate
NO:    FE-2106-310-S
TRIM:    194-649
PAINT:    256-2051
RPO:
TOP
*** There could be inconsistencies in the identification data - please check you entered it correctly ***
Unable to calculate manufacture date without the engine number
That interior trim code is for an FC-2106!
Other Details
Chassis Number:    8-2627-S
Engine Number:    XXXXXX
Results and Explanation
FE-2106-310-S   Vehicle is an FE Utility, the 310th manufactured in Sydney, NSW.
194-649   The Exterior Trim Code (194) describes this car as Single-Tone: Skyline Blue.
The Interior Trim Code (649) refers to: Peasant Blue.
256-2051   The paint colour is Skyline Blue (in DUCO Lacquer)
8-2627-S   The vehicle was assembled during 1958, and was the 1,627th FE (in any bodystyle) assembled in Sydney, NSW.
XXXXXX   Manufacture date (based on engine number) is Unknown (Not a valid grey motor engine number)
fe1957
Turbo Charged
« Reply #433 on: July 07, 2014, 06:45:15 PM »
Hi Pete, you typed in fe instead of fc for your id plate  Grin
ID Plate
NO:    FE-2106-310-S
TRIM:    194-649
PAINT:    256-2051
RPO:
TOP
Other Details
OFE570
« Reply #434 on: July 07, 2014, 06:58:35 PM »
Lucky im good at metal work im not real good on the computer  Grin
Phew would have felt dirty owning 2 FE,s Cheesy
Shes an earlly one.
 NO:    FC-2106-310-S
TRIM:    194-649
PAINT:    256-2051
RPO:
TOP
Other Details
FC-2106-310-S   Vehicle is an FC Utility, the 310th manufactured in Sydney, NSW.
8-2627-S   The vehicle was assembled during 1958, and was the 1,627th FC (in any bodystyle) assembled in Sydney, NSW.
« Last Edit: July 07, 2014, 07:04:12 PM by FCRB26 » Logged
« Reply #435 on: July 07, 2014, 09:12:54 PM »
According to a bulletin dated 15 Dec 1958, the "FC" prefix started on vehicles after this date. So early FC's like this one had "8" prefix rather than "FC"
ken
« Reply #436 on: July 07, 2014, 10:05:35 PM »
Thats awesome documentation Ken.
Thanks.
« Reply #437 on: July 08, 2014, 06:29:12 AM »
Whoa your full of good info Ken!
CraigFC
« Reply #438 on: July 08, 2014, 08:55:57 AM »
 Pete as usual, Great work, this is going to be one super neat FC ute. Are you sticking with the red or are you going back to original colours?
« Reply #439 on: July 08, 2014, 09:22:39 AM »
Unsure yet on colours.
What do people do with there chassis numbers being so faint ?
I re engraved mine and did a rebirth today Cheesy i will tack the old tag under the dash or something just didnt want to have to re stamp it.
Pages: 1 ... 20 21 [22] 23 24 ... 48   Go Up
Page created in 0.156 seconds with 18 queries.
