May 23, 2025, 08:04:36 AM *
Author Topic: Petrol Breather Pipe  (Read 1832 times)
Shane 05
« on: January 27, 2013, 06:53:24 AM »
Hi, just bought the fc from victoria.  We have very strong petrol smell particularly in the boot & its extremely hard to put fuel in the tank, keeps clicking off & only takes a small amount at a time.  There is no apparent leak.  Does anyone know whether it has a breather pipe & could it be blocked & where is it ? Cheers Shane
« Reply #1 on: January 27, 2013, 07:09:24 AM »
No breather mate it breaths thru the cap.
could be leaking through the sender unit might need a new gasket or the sender may have rusted out ?
In the boot you will see the wires going under a round cover with a slot pry this cap out and see whats going on.
I have never had a drama with it clicking when filling but i hold the bowser nozzle sideways ..
Check around top of tank for seepage it may have rusted as well.
May be worthwile removing it and give it a clean up only takes 20 min to remove.
Good luck \\\Pete
Shane 05
« Reply #2 on: January 27, 2013, 07:44:34 AM »
Thanks Pete for the advice, will give it a try!
DN2168
See you on the road Skag!!
dean.nommensen
« Reply #3 on: January 27, 2013, 09:08:52 AM »
Hi Shane,
I had the same smell in my FC, mostly just after it had been filled right up. I removed the sender & cut a gasket out of gasket paper the coated it with aviation gasket sealer both sides & haven't had a problem since. Lke Pete said yuo will have to work out the right angle of the dangle for filling your car up, I work at a servo & new cars are not much better.
Dean.
