July 18, 2025, 03:11:30 PM *
Author Topic: Tightening swivel ball joint on mirror ???  (Read 2668 times)
Dave Lakin (Davo Lako)
« on: January 21, 2013, 12:58:36 PM »
http://i1211.photobucket.com/albums/cc439/DavidLakin/photo33_zps6a653982.jpg
Any tips on how to tighten these Huh
Mine is as loose as a Nan's nasty ... The screw doesn't help ... Squrt in some silicone or glue Huh
Any ideas fellas Huh
Cheers , Dave .
When I was a young man I spent most of my money on cars , beer and women (in that order) ... the rest ... I just wasted !
Port Macquarie NSW
Rusty_T
« Reply #1 on: January 21, 2013, 04:08:10 PM »
Dave,
That little screw on the back of the mirror normally tightens them.
Rusty
« Reply #2 on: January 21, 2013, 05:54:43 PM »
When these are over tightened the dish on the back of the ball gets deformed and no longer holds the ball tightly, unfortunately the only way to fix properly is to remove the mirror and repair the dish and then replace the mirror
Stewy
sa-club
Jeff Stewart
« Reply #3 on: January 21, 2013, 06:25:58 PM »
If you can remove the screw you might be able to put in the hole something of a slightly smaller diameter as a spacer to put a bit of pressure on the dish, but only if the thread in the housing hasn't been stripped.
If it is I would probably go the clear silicon once the mirror is in the correct position.
Cheers Stewy   Cool
Maco
« Reply #4 on: January 21, 2013, 09:15:58 PM »
Dave,
TOO much tension on the screw!!
Better in Green
