June 21, 2025, 07:24:00 AM *
Author Topic: 14 inch wheels for FE  (Read 6673 times)
moetstockie
« on: December 23, 2012, 04:44:55 PM »
Can anyone tell me if there are 14 inch rims/wheels that bolt straight onto my FE standard steering gear. Drum brakes are standard also. Cheers Moe`t
fink fc
« Reply #1 on: December 23, 2012, 05:29:37 PM »
Holden,HK,HT,HG.
jack_fc
SouthWest Coast, Victoria
« Reply #2 on: December 23, 2012, 06:29:10 PM »
HK has different offset to HT/G, and make sure you use the correct nuts...
moetstockie
« Reply #3 on: December 24, 2012, 06:28:29 PM »
Can you tell me how to identify these. Do they have stamps on the rim etc.   Also what's the best size tyre to use on these. I'm using 175/80/13" and trying to improve highway revs and fuel economy.... any comments or ideas appreciated. She revs a little hard at 100k and i do a bit of highway driving. Again standard steering gear and std drum brakes.   Cheers Moe`t
newman
The older I get, the faster I was !!!
« Reply #4 on: December 24, 2012, 08:23:23 PM »
Later diff centre helps 3.55 or 3.36, as long as they are coarse spline diff centres its a straight change over, I run a 3.36 in mine but my grey isn't stock Wink
This link will help you work out which tyre on 14" rims might be the best for you http://www.kabamus.com/garage/gears.html Just put in your details and experiment with tyre sizes.
HT / HG rims are just plain steel 14" rims, the HK series have eight distinct slots in them.
Moe use the gear speed link and I'm sure you'll bring those revs down at highway speed, don't know where you are but I have a spare 3.55 centre if you end up wishing to change your diff centre Smiley
Mick Cool
jack_fc
« Reply #5 on: December 24, 2012, 08:59:35 PM »
the slots are in 4 pairs; you can't miss them, and HT/G rims 'stick out' about 1/4" more than HK, but they're all the same size 14 x 5" and same PCD as FE/FC.
I'd go the HT/G rims... (with whitewalls and baby moon hubcaps  Wink Cool Cool)
newman
« Reply #6 on: December 24, 2012, 10:18:28 PM »
Thats a better way of describing them Wink and good to hear from another fan of steelies,moons and whitewalls Grin Grin
Mick Cool
waynos
patience grasshopper
« Reply #7 on: December 27, 2012, 09:15:56 PM »
 would just like to add that those moons look great on the back widened to 7 inch with 4 and 3/4 backspace with 235/70s Cool
jack_fc
« Reply #8 on: December 28, 2012, 09:10:14 AM »
Mick Cool
Only way to go, Mick...  Smiley
Moet, if you go HT/G rims, be sure to get wheel nuts to suit. While they are the same size/thread as FE nuts, the chamfer on the bottom IS different.
Using FE wheel nuts on HT/G wheels can easily lead to wheels disappearing into the scenery; this can be a little disconcerting at highway speeds...
jack
« Reply #9 on: December 28, 2012, 10:06:49 AM »
More options here - http://fefcholden.org.au/forum/index.php/topic,17575.0.html
Page created in 0.033 seconds with 21 queries.
