August 16, 2025, 02:13:31 PM *
Author Topic: re dropped spindles  (Read 1873 times)
« on: December 18, 2012, 10:50:17 AM »
I am on the lookout for a set of dropped spindles to suit commodore brakes if anyone can help.
Pete
« Reply #1 on: December 18, 2012, 11:47:21 AM »
Pete your a couple of weeks to late sold to a guy in Tas ,,,,,FC427........
« Reply #2 on: December 18, 2012, 12:28:30 PM »
Dammmm
Geoff_K
The 2 BAY s
« Reply #3 on: December 18, 2012, 05:43:48 PM »
Hi Pete,
I have a new STUBTECH set (17.9.11 with paperwork) to following detail:
STUBTECH STUB AXLES—RANGE OF MODELS.
HD-HR Standard Steering: Brake callipers are mounted to the front, steering arms to rear
and are bolted to the lower holes.
HD-HR Rack 8, Pinion Steering (Torana): Brake callipers to rear, steering arms to front, and
bolt to lower holes.
HK-HT-HG: Brake calliper to front when using Girlock callipers. All others do not matter.
Steering arms to the rear, bolt to top holes.
HQ-WB:  Brake callipers to rear, steering arms to front, and bolt to top holes.
LH-LX-UC: Brake callipers to front. Steering arms to front and bolt to lower holes.
Tapped hole in steering arms to be drilled out to accept a 7/16" UNF Grade 8.8.
LC-LJ: Brake callipers to rear. Steering arms to front and bolt to lower holes. Must be
stamped 90•
STUBTECH STUB AXLE WILL LOWER CAR APPROXIMATELY:
MODEL     DROP AT WHEELS      WHEEL DIAMETERS
HK-HT-HG-WCI-WB     50mm     14" Wheels
                                               7.5 degrees
HD-HR                       60mm     13" Wheels
                                               7.5 degrees
LC-LJ-LH-LX-UC         60mm      13" Wheels
                                               9 degrees
I understand that Commodore Hubs/Stud Pattern/Brakes fit, but you would have to verify (as I was going to fit Std HR brakes/hubs)
Interested?
Geoff_K
« Reply #4 on: December 18, 2012, 06:31:57 PM »
Thanks for the offer Geoff but a member rang me today with an earlly CRS set so i will go that way as he wants to barter with me so im very happy with that..
Ill let you know if i have any dramas.
Peter Mallaby
Page created in 0.02 seconds with 16 queries.
