May 21, 2025, 05:41:54 PM *
Author Topic: FE Hidden Wiring  (Read 8862 times)
perth_ute
« on: November 26, 2012, 12:22:56 PM »
Hello All,
After many months nearly years I am ready to do the wiring and would like it to be hidden. I have heard of putting the headlight wiring under the gaurds which seams like a good idea as long as it is secure and protected.
First question is where to drill the hole to go back into the cabin from under the wheel arch.
Second is what fuse boxes have been used and where to locate with relays?
David.
NosFEratu
F4+ =^^=
« Reply #1 on: November 26, 2012, 03:18:24 PM »
In our van we
* fed the wiring through a hole under the A pillar (under the right had front guard)
* the loom under the guard is encased in split loom and attached to tabs I welded high up on mudguard side of the inner guard.
* the right hand headlight/park light/indicator is separated into another split loom and terminated near the headlight
* left hand stuff and fans continues in the loom down the outside of inner guard
* a hole is drilled at the bottom of both inner guards (in front of the radiator) for the loom to be put though to the fan and horns and through to the left hand side lights.
You need.
* a step drill
* grommets for the holes to protect the wiring
* split loom to protect the wires
* tabs to tie the loom to
* a bit of time.
regards
NosFEratu
perth_ute
« Reply #2 on: November 26, 2012, 03:46:22 PM »
interesting...
I am think of putting a vp/vn/vs fuse/relay unit where the original fuse panel is as there are plenty of fuses and relays.
Not sure of where you are putting the hole. Is it just above the A piller so next to the accel pedal. I was wondering if people have put the hole at the top above the door hinge?
« Reply #3 on: November 26, 2012, 05:29:08 PM »
Hi Mate do yourself a  favour and buy an aftermarket  wiring harness/ fuse panel chopping up an old fuse panel just takes so much time and effort extending wires ect.
A good aftermarket wiring kit is pretty cheap and makes life a lot easier.
I drilled my holes up high nearlly at the top of the guards and i had M6 bolts welded along and clipped the harness to it with P clips..
Pete
perth_ute
« Reply #4 on: November 26, 2012, 07:19:49 PM »
yeah I hear you about the spagetti mess. You would not have a pic of were you drilled the hole? I see there are two pressed indents above the top of the door hinge on the side is this where you went?
« Reply #5 on: November 26, 2012, 07:31:53 PM »
theres a storm now ill take a pic of the half cut FC i have here..
Not Happy Jan
Aussie adventure
« Reply #6 on: November 26, 2012, 11:43:59 PM »
Is that the fc or you half cut or both Grin
You can never have too many!
Port Macquarie NSW
GMB-58FC
Stage one complete...
« Reply #7 on: November 27, 2012, 12:07:14 AM »
I've been trying a few things myself (a little hard as I haven't completely removed the engine) but will take some pics tomorrow so you can see how I've gone about it.
ABS Hobart- 6231 5855
PM FOR QUOTE
« Reply #8 on: November 27, 2012, 04:15:47 AM »
Ha ha
I have a fc front half cut / garden ornament
newman
« Reply #9 on: November 27, 2012, 02:13:31 PM »
Ha ha
Gotta be better than garden gnomes or concrete frogs Cheesy Cheesy Cheesy
Mick  Wink
FireKraka
« Reply #10 on: November 27, 2012, 02:37:22 PM »
I used a V6 conversion wiring loom and have tried to hide as much as I can.
I am in Perth so if you would like to have a look send me a PM
Neil
« Reply #11 on: November 27, 2012, 04:26:56 PM »
Had a quick look my harness runs out next to the bonnet cable thru the firewall behind the dash guages ect..
« Reply #12 on: November 27, 2012, 06:25:48 PM »
Neil
That's for a V6, What engine are you running David?
FireKraka
« Reply #13 on: November 28, 2012, 11:03:16 AM »
The positions to run wiring through the firewall don't change much. No matter what engine your running there are only so many places you can drill holes or is that too hard for you to figure out by yourself as well NES
« Reply #14 on: November 28, 2012, 11:46:54 AM »
Hope your not having a go there mate.
It's completely different from my grey engine.......Plus a shitload more wires. A grey engine wire harness would be a dam site easier to hide than that of a VT
FireKraka
« Reply #15 on: November 29, 2012, 10:41:51 AM »
Apologies NES didn't mean it to come out like that bad hair day at the office (and I don't have any hair) shouldn't have posted anything yesterday it was that bad.
You are right about the amount of wiring for different engines of course but I thought the question was mainly referring to headlight wiring?
Neil
perth_ute
« Reply #16 on: December 11, 2012, 07:48:04 PM »
Sorry for the delay. The bank has made me work...
I have started making my own loom. Runs under the top lip of each guard to just behind the dash and glovebox. Running the high beam just alittle up and then under the hand brake cable. Currently running holden 8 and then injected. Will run injection wire on the side of the gbox. Replacing the fuse tray with commode due and relay from vp.
