September 02, 2025, 08:09:44 AM *
Author Topic: FC windscreen chrome strip removal  (Read 3194 times)
curlslinc
« on: September 25, 2012, 03:56:30 PM »
Hi all , what else holds in place the chrome strip at bottom of windscreen besides the two screws. I have water leaking into dashboard via one corner where I suspect more sealant needs to be "pushed in " under the good condition rubber seal . any suggestions please ? Curly
freddyc
« Reply #1 on: September 25, 2012, 04:00:54 PM »
the chrome strip is held in by the rubber. I think (I am not a guru) the strip is like a T peice with the back of the T fitting into a grove in the windscreen rubber. You have to remove windsreen to remove chrome strip. Is the leak coming in over the rubber? if so you can fit the sealant nozzle under the rubber and reseal.
fred
Townsville North Queensland
curlslinc
« Reply #2 on: September 25, 2012, 04:46:48 PM »
Thanks for prompt reply, yes it is coming in over the rubber or in between rubber and glass , so was thinking of pushing nozzle in as you suggested.
« Reply #3 on: September 25, 2012, 05:17:04 PM »
As Fred said , the best way is to fill the gap between the screen and rubber, it is best to seal all the way around. For the best result, cut the nozzle about an inch up from the point on a slight angle then flatten it with pliers tis will make it much easier to pust the nozzle into the rubber, then work your way around the screen making sure you get a excess bead behind the nozzle. Once you have gone right around, clean up the excess with a flat scrapper and then wipe off with a kero or turps rag.I do this for a living and thats the best way to get a good seal.
Regards Jim
curlslinc
« Reply #4 on: September 25, 2012, 07:44:47 PM »
Jim , thanks a lot for your guidance, will do it as you recommend.
Page created in 0.028 seconds with 16 queries.
