September 09, 2025, 10:21:52 PM *
Author Topic: seatbelt installation  (Read 2061 times)
FC 304 wannabe
« on: September 19, 2012, 09:24:02 PM »
hi, does anybody know of a post in this forum showing how to install seatbelt mounts?
just about to start on mine and figured the more info the better...
pictures would be good  Smiley
« Reply #1 on: September 19, 2012, 10:19:59 PM »
there are a few in the project cars,depending on what you want to install,fixed belts or retractables,front and rear etc. I've almost finished mine,I'm fitting retractables front and rear with lapshash in the middle. Made up some 3mm mounting plates 150x65mm and found that the wheelnuts are the same size thread and welded them to the plates. I'll take some shots and post them in the next couple of days. I've welded the lower b pillar plates to the pillar and the floor,although some others have made angle brackets and welded them away from the pillar.
Regards Jim
