July 17, 2025, 02:56:53 AM *
Author Topic: wiring up a gen light  (Read 4084 times)
andykotzur
« on: September 05, 2012, 08:12:07 PM »
Hello all
Does anyone have advice for wiring up the gen light on the dash when using a alternater? Bloke that sold me the alternater said to run a ignition power wire through the light, then off to the alternater to excite it into charging the battery. Its not charging at the moment. Any help would be good as I am afraid of damaging something.
Andy
« Reply #1 on: September 05, 2012, 09:12:57 PM »
Should not be necessary - does your alt have inbuilt or separate reg?
« Reply #2 on: September 06, 2012, 08:32:37 AM »
Andy,
As Ken says, not all alternators require an exciter, however if you are using one that does,  I did some research to work out the exciter circuit some time ago when I was using a camira alternator.
More in the thread below, although some of the problems I experienced were from incorrect pulleys ultimately.
I did post up some part no's of resistors or bulbs you could use.
http://fefcholden.org.au/forum/index.php/topic,11884.0.html
andykotzur
« Reply #3 on: September 09, 2012, 04:50:01 PM »
I think it has an inbuilt regulater. The original wire from the gen light has 12volts of power. I ve hooked it to the w (warning, I guess) lug on the alternater but it still wont charge. Does the alternater need to be earthed?, as mine is mounted through rubber cushioning mounts, so its maby not earthed.
OldGMHolden
« Reply #4 on: September 09, 2012, 05:20:23 PM »
YES!!!
Connect a wire from alternator body to engine block, minimum size same as alternator (+) wire, and as short as practical.
Make sure of a firm bolted connection, with proper terminals.
Should fix it immediately if there are no other burnt-out bits.
Ol'Gaz
andykotzur
« Reply #5 on: September 09, 2012, 07:58:33 PM »
Success at last. It was the earth. The aircon mount ive used is soft mounted, and the alternater sits on top with a soft mounted adjustment rod. All good now. Thanks for your help.
Andy
Page created in 0.028 seconds with 19 queries.
