July 18, 2025, 02:26:06 PM *
Author Topic: accelorator pedal and cable  (Read 3636 times)
blakbrute58
« on: September 04, 2012, 12:22:15 AM »
what pedal and cable would go into fc with red motor
« Reply #1 on: September 04, 2012, 06:52:43 AM »
Any pedal and cable will fit, if you have the patience and gasaxe skills  Grin.
Only kidding -  HZ fits OK, as does Commodore. The Guide below gives a step by step process for fitting Mitsubishi cables in a simple (bolt up) way.
http://fefcholden.org.au/forum/index.php/topic,20117.0.html
Harv.
« Reply #2 on: September 04, 2012, 04:44:45 PM »
There is also a thread on this site with pics of fitting a Commodore cable. Very easy once you have the mounting bracket sorted.
FCV08
FE FC Club of QLD
« Reply #3 on: September 04, 2012, 08:48:25 PM »
After modifying and fitting a VN pedal setup I had a look at a VR-S and the mounting bracket looks a whole lot easier.
Craig D ( Build - Here we go again!!)
« Reply #4 on: September 06, 2012, 12:04:58 PM »
I have a VT setup which is quite good. Previous to that for my grey I had a Rare Spares one that fed the cable through and acted as a bonnet hinge bolt. I now no longer need the pedal and you can have it but I am using the rest of the cable.
I also have a full VS set of pedals with booster and brake master. I am wanting to sell them with my V6 and may be coerced into separating them.
Page created in 0.088 seconds with 16 queries.
