April 05, 2025, 01:18:07 AM *
Author Topic: Identify Block as Red or Blue motor?  (Read 4755 times)
heavyduty1340
« on: August 27, 2012, 11:22:12 AM »
Can anyone id a block from the engine no etc to help me find out if the motor in my FE is a red or blue motor
I was informed by an engine reconditioner that both red and blue motors cam stamped as 3.3l???
I am currently building up a hot 3.3l black motor with blue motor head for the old girl
The logic behind this is that he also told me that starfire rods wont clear the sump on a red motor, but the blue sumps had clearances ground into them??? I am trying to find out if I need a different sump now or not.
« Reply #1 on: August 27, 2012, 11:54:25 AM »
can you supply the engine number ?
« Reply #2 on: August 27, 2012, 10:20:46 PM »
EH Sump fits the  Blue Black  no problems camshaft need to be 202/ 3.3 not 179/186 ......FC427.....
heavyduty1340
« Reply #3 on: August 28, 2012, 06:11:14 PM »
Engine No is QL387844   3.3l on block
Hopefully Ive already got the sump covered then
Now just want to find out if block is red or blue (currentlly 2 pac kermit green)
earlyholdenfan
« Reply #4 on: August 28, 2012, 06:39:11 PM »
Pretty sure QL was red from HQ to HZ series - but don't quote me
Matt
spanner
Mackay QLD
« Reply #5 on: August 28, 2012, 07:09:31 PM »
All here.
http://www.monaroparts.com/Engines.htm
heavyduty1340
« Reply #6 on: August 28, 2012, 08:07:44 PM »
Thank you
That rules it out being a blue motor then Undecided
As long as the sump that is on it suits a black motor I am building, and clears the starfire rods I am fine then
heavyduty1340
« Reply #7 on: August 28, 2012, 08:55:18 PM »
Shoot - just realised that now that we have worked out the motor is a red one, I am worried the head isnt a 12 port, hence intake manifold and extractors will need changing.
I have a set of VH commodore blue motor extractors and std intake - will the extractors be a close fit, and can intake be modeded to accept holley?
Damn, I thought this would be an easy quick swap - DOHHHHHHHH.
