August 14, 2025, 05:06:24 AM *
Author Topic: FC Ute drivers door window glass  (Read 2570 times)
RichFC
« on: August 15, 2012, 06:53:42 AM »
Hi There, not sure if ute glass is the same as sedan glass, but i need glass for ute as well as window winding merchanism.
Thank you very much !
« Reply #1 on: August 15, 2012, 09:06:29 AM »
I have the centre piece rear and a front screen. Showing their age, the ute has an extra piece at the sides of the rear.
Where are you located?
RichFC
« Reply #2 on: August 15, 2012, 09:11:41 AM »
Hi There, Thank you very much for your response and offer.
I actually didnt write my request correctly I actually need drivers door glass and winding mechanism regulator
and steel rail that window fits into onto regulator.Hope that makes sense.
Im in Hurstville Sydney !
87 velo
Sydney
« Reply #3 on: August 15, 2012, 08:17:17 PM »
Utes have a rounded rear edge on the side windows, so they are different from the sedans, If you need a RH window regulator most you will find are worn out or close to, LH ones are usually pretty good, its possible to convert a left to a right without too much effort.  thats what I did for mine
RichFC
« Reply #4 on: August 15, 2012, 08:18:08 PM »
Excellent,thank you very much!
waynos
patience grasshopper
« Reply #5 on: August 16, 2012, 05:42:28 PM »
pm sent
Page created in 0.024 seconds with 16 queries.
