September 08, 2025, 02:22:50 AM *
Pages: [1] 2 3   Go Down
Author Topic: FantaC`s FantaE  (Read 22653 times)
FantaC
loose nut
https://www.facebook.com/
« on: August 11, 2012, 07:50:30 PM »
we just bought an FE
body wise its perfect with a small amount of surface rust near the back window
Will post the body numbers when we get it home
comes with everything and a spare motor
the white marks on the rear seat is paper stuck to it
FantaC Customs
« Reply #1 on: August 11, 2012, 08:15:01 PM »
Nice! Do you still have your van?
FantaC
loose nut
« Reply #2 on: August 11, 2012, 08:29:46 PM »
Yes i do . I did try and sell it but must of been asking to much for it . I was lucky enough to find 4 nos sills just need to fit them and weld up the sunroof hole . We also have 2 EH`s and a 1 Tonner now . Ya can never have to many Holdens . Do you still have your Van ?
FantaC Customs
« Reply #3 on: August 11, 2012, 08:35:02 PM »
No mate that went about 3 years ago to a very good home. Good luck with the sedan and keep that photos coming!
FantaC
loose nut
« Reply #4 on: August 13, 2012, 05:23:14 PM »
here are the numbers can someone tell me about them thanks
FantaC Customs
« Reply #5 on: August 13, 2012, 10:00:33 PM »
If you have the chassis no. and the engine no. you can go to the technical info section at the start of the forum and go to the decode your vehicle section and it will give you all the info on your car. I have entered your body numbers and this tells me your car is the 13,114 th car built in Adelaide, it is a single tone of Frankstone cream with Fall Red and Parchment Ivory trim.
Hope this will help, Jim
FantaC
loose nut
« Reply #6 on: August 14, 2012, 12:05:48 AM »
Thank you so much Jim
 Wink
FantaC Customs
FantaC
loose nut
« Reply #7 on: August 17, 2012, 06:05:01 PM »
Couple more pics
FantaC Customs
FantaC
loose nut
« Reply #8 on: August 17, 2012, 08:31:05 PM »
got it running today , a little ruff .Put water in radiator and it went straight to the sump and exhuast is now leaking ... not fumes ... water
FantaC Customs
FantaC
loose nut
« Reply #9 on: August 17, 2012, 08:32:29 PM »
FantaC Customs
TTV6FC
« Reply #10 on: August 17, 2012, 09:09:38 PM »
ooohhhh bugger,that's not good.Obviously... Roll Eyes
sunnytim
« Reply #11 on: August 17, 2012, 09:33:08 PM »
I had that happen to me once on an EJ I had, pushed water out the exhaust.  THought it was a head gasket so pulled the head off, replaced it and put it all back together.  Started it up, ran fine then filled the radiator and THE SAME THING HAPPENED  Huh
It ended up that there was a small corrosion hole inside the valve chamber of No 1 cylinder.  Head off again, whacked another one on and voila  Cheesy
So long of the short, I have seen greys more recently develop holes in the head either in and around the valves (and the flat area of the head above the piston) must just be the age they are getting to.
FantaC
loose nut
« Reply #12 on: August 18, 2012, 04:59:00 PM »
Thanks Guy`s will pull the head of soon and have a look . I hav`nt played with a Grey motor since i was 18  hope i remember how Smiley
FantaC Customs
FantaC
loose nut
« Reply #13 on: August 18, 2012, 06:13:22 PM »
FantaC Customs
TTV6FC
« Reply #14 on: August 18, 2012, 07:41:10 PM »
What's wrong with that...? Tongue
FantaC
loose nut
« Reply #15 on: August 18, 2012, 08:40:08 PM »
Im not a machanic but the head looks fine so of to the parts shop tommorow for a gasket set
FantaC Customs
Rod
« Reply #16 on: August 19, 2012, 09:40:11 AM »
Difficult to tell entirely by the photo's but there is evidence of leakage between water jackets and cylinders in 1, 2, 3 and 4. Hard to say with others. It would be good advice to get pressure and crack tested and check for warpage. There is room for a grind as the thumb print is present.
Rod
FantaC
loose nut
« Reply #17 on: August 19, 2012, 11:10:01 PM »
Took a gamble and bolted it back on . she runs sweet even gave it a recon paint job Smiley it was painted light grey as you can see on the valves . Painted the manifold a cast colour kinda looks silver in the photo
FantaC Customs
fink fc
« Reply #18 on: August 19, 2012, 11:27:15 PM »
Now you can get out and drive the tyres off,nice work on the xw/xy,i'm doi'n an xr fairmont,  Cool Gaz!
FantaC
loose nut
« Reply #19 on: August 24, 2012, 02:50:38 PM »
Will do as soon as i get her lic
cant seem to find the Chassis number
« Last Edit: August 24, 2012, 02:57:37 PM by FantaC » Logged
FantaC Customs
Pages: [1] 2 3   Go Up
Page created in 0.043 seconds with 17 queries.
