May 24, 2025, 09:02:36 AM *
Author Topic: steering coloum  (Read 4818 times)
aussieute
« on: July 22, 2012, 01:33:48 PM »
hi all  does anybody know of a coloum that will suit a front mount rack i have a standard modified fc in it but is to far from dash i was thinking vl commodore any tips thanks john
« Reply #1 on: July 22, 2012, 02:14:18 PM »
did you want to keep column shift?
« Reply #2 on: July 22, 2012, 09:57:13 PM »
Tirana is often used
aussieute
« Reply #3 on: July 23, 2012, 03:06:58 PM »
hi thanks no i dont need shifter on column as i have floor shift just need to get wheel away from big gut and the shaft  keeps poping out of joint where bolt goes thru very scary steering wheel spinning so i am tossing steering to try some other way
weddo
HIS, HER's & OUR's
billnjudiwedd@gmail.com
« Reply #4 on: July 23, 2012, 09:11:23 PM »
You can always shorten the column you have.
Cut down outer tube, shorten the shaft and have it re splined and thread re cut.
I've had mine shortened 3 inches including gear change tube.
regards
Weddo
« Reply #5 on: July 24, 2012, 05:12:05 AM »
I shortened mine and you are allready running a rack so do it on the bottom side have it machined to accept your uni and just cut your tube down.
I assume you have a nylon bush in the bottom of the colum allready so remove it and shorten it up from there.
aussieute
« Reply #6 on: July 24, 2012, 10:13:24 AM »
thanks for the ideas will do that
