July 17, 2025, 11:31:54 AM *
Pages: 1 ... 17 18 [19] 20 21 ... 41   Go Down
Author Topic: Heart Transplant - adding 172ci  (Read 488162 times)
« Reply #360 on: August 20, 2013, 02:07:41 PM »
Just wondering if those mounting brackets on the backing plates are going to scrape the inner guards or have you already ollowed for that. I didn't look all the way through the photos carefully but all the commodore rear ends I've put in I had to relocate those brackets so the hoses wouldn't shear off with suspension travel. Just think its worth a look. Cheers
What mounting brackets are you talking about Huh
« Reply #361 on: August 20, 2013, 03:45:28 PM »
My backing plates and hoses clear .
Mines late model vs?
« Reply #362 on: August 20, 2013, 04:09:53 PM »
Same
Same
« Reply #363 on: August 20, 2013, 05:35:00 PM »
Yeah Physio isn't as good as Chiro from Mum's point of view too and she has this disease severely. The shed is progressing and the frame should be completed tomoz.
« Reply #364 on: August 21, 2013, 08:15:52 AM »
Hahaha you must be excited, seen that on three different posts now  Cool
« Reply #365 on: August 21, 2013, 10:12:26 AM »
My backing plates and brackets are wholly contained within the rim
« Reply #366 on: August 22, 2013, 01:18:27 PM »
Re doing the fuel and brake lines is a real bitch to do but thanks to FCRB26's custom fuel line clamps its looking pretty
FCV08
FE FC Club of QLD
« Reply #367 on: August 22, 2013, 09:00:56 PM »
Noice  Grin Grin Grin
« Reply #368 on: August 22, 2013, 09:15:17 PM »
Thanks Craig.
Just saw the bottom of the last pic and the pipe is scewed off as I was still going on the backend of it and this was a progress shot. The first line is easy - trying to match the others is difficult
FCV08
FE FC Club of QLD
« Reply #369 on: August 22, 2013, 09:21:53 PM »
NES
as long as you're happy.
At the end of the day unless your showing underneath this would no doubt be sufficient.
BTW went to a show and shine on the weekend which was a part of the Leyburn sprints and took out Car of the Event. Great surprise and very unexpected as I didn't even clean it other than chamois the bugs off the windscreen and front of the car. Many were intrigued how it all fitted in under the bonnet.
Craig D
« Reply #370 on: August 22, 2013, 09:53:24 PM »
Whoa Craig!  Nice!!!
« Reply #371 on: August 23, 2013, 09:31:07 AM »
Nice lines and install NES.
Where did you get the tube?  is it aluminium or steel?
« Reply #372 on: August 23, 2013, 10:01:54 AM »
Thanks ED. It's steel and a pain in the abdominals, laying under the car in a half situp hurts after two hours! I tried to bend it while off the car but was doing a crap job. The pipe bender I have kinked the larger tube as soon as it got passed 70deg so my hands are killing me from bending by hand Angry BUT it is coming up good and the Clamps Pete (FCRB26) made are gold (well aluminium but awesome bits now added to his catalogue).
I got the lines from First choice Brakes at Cardiff in Newcastle. They call it "Bundy line" and about $40 for a 6m length of 3/16 brake line (thinner one). Think I paid about $60 for the the larger one but I had all the fittings and P clips as well.
« Reply #373 on: August 24, 2013, 08:20:03 PM »
Well I wanted to clear up the flare definitions. I am doing SINGLE flares. Picture shows ball shape is a single flare that Holden use and right is a double flare. The double flare is just a single flare that has been pushed in. Ps arrows are for Pete
« Reply #374 on: August 25, 2013, 02:51:48 AM »
I found a problem with the brake line from the calipers, they fowl on the crossmember. I haven't cleaned it yet so no comments on the dirt.
I bought these to get around it as they didn't swing out as far
Will need a quick touch up paint.
« Reply #375 on: August 25, 2013, 03:00:36 AM »
I'm gunna pull the front end out soon to paint it up...
NickZ
« Reply #376 on: August 25, 2013, 10:01:33 AM »
so are you going to tell us what the new brake hoses are off? also at full lock will the bolt on the caliper holding on the hose hit the Xmember?
« Reply #377 on: August 25, 2013, 04:20:27 PM »
They're off the VT as standard with a different fitting- nothing special. Unfortunately the bolt does fowl on the lip of the crossmember.
NickZ
« Reply #378 on: August 25, 2013, 06:14:14 PM »
so you got a new end fitted?
mine is the same as yours and the bolt hits but thats only with on weight on it, i have not got my steering on yet, will the steering get that far on full lock that it hits?
« Reply #379 on: August 25, 2013, 06:51:59 PM »
Unknown. No weight right now. Engine out
Out
Pages: 1 ... 17 18 [19] 20 21 ... 41   Go Up
Page created in 0.065 seconds with 17 queries.
