August 20, 2025, 01:24:32 AM *
Author Topic: Fuel leaking into boot  (Read 3598 times)
DN2168
See you on the road Skag!!
dean.nommensen
« on: July 13, 2012, 09:33:08 AM »
Ever since I bought the car it has had a fuel smell in the cabin after it is filled up. I hadn't been able to track it down until yesterday. Where the sender screws into the tank was a puddle of fuel (I had purposely filled the tank really full). I replaced the sender gasket, but the screws seemed to have washers on them with rubber seals that were all broken & split. I put a dob of silicon on the screws before putting them back in, but it has leaked again over night. Would tread tape on the screws help seal them, or can you still buy the washers? I looked on rares but they didn't list them. Any ideas appreciated.
Dean.
KFH
« Reply #1 on: July 13, 2012, 10:01:33 AM »
I had a small leak in mine as well.  The cure I used was to cut a new gasket out of gasket paper and give either side of it a coating with a non hardening gasket cement, gave the screw threads a light coating of the same cement and screw it together.  No more problems  in 1300 miles.
DN2168
dean.nommensen
« Reply #2 on: July 13, 2012, 12:23:02 PM »
Thanks for your reply Keith. Just finished putting it all back together (with a mouth full of unleaded). See how it goes now, if it still leaks I may have to organise another tank.
Dean.
« Reply #3 on: July 13, 2012, 04:48:14 PM »
None of the silastics are going to work as the fuel dissolves them. The original washers are lead. Keith's solution seems OK with a hard setting cement. I have screws here with good washers for $10 a set.
DN2168
dean.nommensen
« Reply #4 on: July 13, 2012, 05:59:43 PM »
Thanks Ken,
I will see how it goes on the weekend & if it still leaks I will get in contact to arrange a set of screws.
Dean.
DN2168
dean.nommensen
« Reply #5 on: July 14, 2012, 05:18:31 PM »
24hrs.....so far, so good Grin
Page created in 0.022 seconds with 16 queries.
