May 24, 2025, 11:56:44 AM *
Author Topic: Firewall mounted brake booster  (Read 3113 times)
Oggz
« on: July 13, 2012, 08:00:32 AM »
Am planning to put a trimatic behind the grey and have been advised that boosting the drums would be a sufficient upgrade to the brakes that I wouldn't need to do a HR front conversion.
Can anyone recommend a firewall mounted booster w/master that would be relatively easy to attach knowing that the clutch master will be deleted?
I figure if I just go single circuit master then I wouldn't need to make too many if any changes to the rest of the system.
Jemahl
« Reply #1 on: July 13, 2012, 08:42:53 AM »
Why do you want to run drums?
« Reply #2 on: July 13, 2012, 09:36:14 AM »
If your brakes are fine now I wouldn't mess with them, sure you're going to lose some engine braking going from manual to auto but I don't think it would be worth the effort. Boosted drums can be tricky and sometimes downright dangerous, especially in emergency braking situations.
« Reply #3 on: July 13, 2012, 01:37:17 PM »
Shift kit in the trimatic to aid with the braking . Grin
« Reply #4 on: July 13, 2012, 04:45:30 PM »
Why not consider the VH40 remote booster solution - much simpler and will be just as good in performance. You could even mount it under the guard to keep it out of the way.
