May 24, 2025, 04:59:07 PM *
Author Topic: removing heater hoses on 5L engine  (Read 3480 times)
FC 304 wannabe
« on: July 08, 2012, 06:59:50 PM »
hi guys,
anybody out there with 304 holden v8 experience,,, I want to iliminate the heater hoses on my fc project car..
is it as simple as blocking the hose at the front of the manifold and looping the two hoses coming off the water pump together? Or is there more to it Huh?
thanks,
Shannon .
john253a
« Reply #1 on: July 08, 2012, 08:09:46 PM »
i just drill and tap the fitting and fit a taped grub screw
Good + Fast = Not Cheap
Cheap + Fast = Not Good
Good + Cheap = Not Fast
FC 304 wannabe
« Reply #2 on: July 08, 2012, 08:13:34 PM »
where do you fit the grub screw to ?
« Reply #3 on: July 09, 2012, 07:15:36 AM »
In the hole im guessing. Grin
john253a
« Reply #4 on: July 09, 2012, 12:39:01 PM »
In the holes where the hoses came off,
Most new pumps have 1 blocked from factory like that and you need to remove if you use
Ole
« Reply #5 on: July 09, 2012, 01:07:56 PM »
Shannon, you should be able to buy rubber cups that fit over the hose outlet that is then secured with a hose clamp. Holdens use to supply them specifically to blank off hose outlets that are no longer required. It looks alot neater than looping the hose from one outlet to the other. This is another option if you don't want to go to the effort of tapping the hole and fitting a tapered plug.
Regards Ole.
Adelaide SA
Page created in 0.028 seconds with 19 queries.
