July 25, 2025, 01:48:57 PM *
Author Topic: Couplertec  (Read 6993 times)
Not Happy Jan
Aussie adventure
« on: June 30, 2012, 07:14:15 AM »
I was looking at putting this system into the babies. Living on the coast is always an issue !
Has anyone installed this device  Huh
Nick
This is their spiel
CAR 2WD Heavy Duty "Self Fit Kit"
Price per Unit (piece): $450.00    (including 10 % tax)
Ask a question about this product
This heavy duty system has been designed to suit all two wheel drive vehicles such as Hatchbacks, Sedans, Large Wagons and Vans. Offering a higher level of rust protection than that of the standard two wheel drive system, this Heavy Duty system will protect larger two wheel drive vehicles including those that reside in Coastal regions and that are located within a very close proximity of the beach, or which are occasionally driven on snow covered roads where de-icing salts and chemicals are being used.
This system will also help to slow corrosion in older cars that may have existing rust. IMPORTANT - as good as CouplerTec is, it is NOT a miracle cure for badly rusted cars. CouplerTec systems can however slow down the process by approx. 80%
You can never have too many!
Port Macquarie NSW
« Reply #1 on: June 30, 2012, 08:39:06 AM »
nothing beats fish oil and tectyl im very sceptical of electronic rust prevenatives.
But i could be wrong .
pete
« Reply #2 on: June 30, 2012, 06:22:16 PM »
Is this system Cathodic Protection  Huh Huh .....FC427.....
Not Happy Jan
Aussie adventure
« Reply #3 on: July 03, 2012, 08:55:47 AM »
yeah I think so... charges the car to prevent the oxidation of the steel.
Port Macquarie NSW
« Reply #4 on: July 03, 2012, 09:43:37 AM »
Nick, I have similar issues...
it's a lot of money to spend to find out yay or nay though.  I live near the water and my ute is suffering....
I find once a year I need to go over the car and just brush paint the underbody with kill rust.  my bonnet release catch even rusts closed!!
every scratch just flares up with rust within a week.
i fish oil the insides of doors and so far so good.
if mounted to the chassis, it would protect the areas which have an electrical contact (if it works).
Im interested to know as well.
Mc Bean
« Reply #5 on: July 04, 2012, 07:46:44 PM »
Hi Nick
This is only my opinion, Being a panel beater for over 25 years I would not buy any form of electronic rust protection. I haven't yet seen or heard any evidence of these devices stopping or slowing down rust.
CouplerTec systems can however slow down the process by approx. 80%, to me that sounds like your car will still rust BUT not as much.
As Pete says a Tectyl or cavity wax Heated a little (to run easier) and sprayed with  a rustproof gun to get into sills,doors everywhere is my proffered solution.
As for chips and scratches, try to touch them up as soon as possible, and any bear metal I would wipe over with Inox or similar product.
Remember this is only my opinion
Andrew
Andy
57effie
« Reply #6 on: July 05, 2012, 03:16:52 PM »
For my two bob's worth, I have spent a lot of the last 33 years on the beach in a variety of vehicles.I have used a variety of different treatments and Electronic corrosion protection for me delivered the best results but they were fitted to new vehicles with no corrosion to start with. They wont stop existing corrosion from spreading and scratches, chips and surface rust still have to attended to regardless.
Simply put, different metal parts have different potentials, that is voltages like the + and - of a battery, and when moisture and oxygen are added the chemical effect is when corrosion occurs. Corrosion can still occur in dry joins up to a point. The electronic units have a series of pads that are applied to different panels around the vehicle and are wired in series thru the unit to eliminate a difference in potential between the panels and thus eliminate corrosion (theoretically anyway).
For new vehicles electronic is the only way to go because they enhance the corrosion coatings that modern cars are treated with but for older cars old fashioned remedies are best.
Flowing types of treatments are the best, not the paint on types that dry but stuff like Fish oils and lanolin based stuff. You can bleed them right into seams rather than just over coating a join and leaving a pocket for rust to start in.  They arent a permanent treatment so you need to keep re-applying but this helps you monitor any corrosion problems you might already have and these products will also halt the spread of anything already existing.
Thats my experience anyway.
Mark
Not Happy Jan
Aussie adventure
« Reply #7 on: July 06, 2012, 12:01:37 PM »
Thanks for all the replies and the insights.
Looks like I'll breakout the lanolin and fish oil.
Nick
Port Macquarie NSW
Oggz
« Reply #8 on: July 06, 2012, 07:52:54 PM »
Nick, try an find something with the smell removed!!! might cost you more but so worth it. I used suppa cheap stuff and it stank out the car for months.
