August 05, 2025, 01:01:36 AM *
Author Topic: Modification Application Light Vehicles- WA  (Read 4366 times)
my59
« on: June 20, 2012, 11:38:34 PM »
Hey all. Hoping to get some help with my application- after some info for the specification questions.
1) Manufacturers original height to the top of the roof on an 1959 FC Special sedan?
2) Manufacturers original tyre size and profile?
3) Original manufacturers wheel track- Front?
4) Original manufacturers wheel track- Rear?
5) Original manufacturers wheel rim width?
And lastly... a question pertaining to the replacement item as opposed to the original equipment:
How do i determine the offset/onset of a wheel?
Many thanks in advance.. and may your projects have progress  Smiley
Jason
spanner
Mackay QLD
« Reply #1 on: June 21, 2012, 07:02:00 AM »
There is a very good wheel offset chart on the Dragway wheels website under car products.
It can be downloaded or printed.
black57
feratrod
« Reply #2 on: June 21, 2012, 07:07:05 AM »
Can't help with much of the OE specs but I can help with the wheel offset.
First write down the wheel width (7", 8" etc), also halve it and you will have a centreline reference. (you'll need this in a minute) You can also now convert these to mm if you like, and do everything else from here on in mm to help your engineer.
Find a straight edge like a spirit level or a piece of steel about 15+ inches long.
Lay the wheel down (gently) on it's face.
Lay the straight edge across the back of the wheel and measure the distance form the underside of the straight edge to the hub mounting service of the wheel (the flat area on the back that sits against the hub when the wheel is on).
You now have the measurement of 'back space'. Write that down.
Now subtract the wheel center line from wheel backspace to get 'offset'.
If backspace is less than the wheel centerline measurment the offset is negative,and if backspace is greater than the wheel centerline measurement the offset is positive.
Now you should have either a neg or pos measurement of offset, as well as a backspace measurement.
PS. To convert from inches to mm multiply by 25.4
Hope that helps.
Pinky
A car on the road is worth 2 in the shed...
FE Standard rat rod
1965 GSM Dart - ex race car
1948 Singer 9
1954 Sunbeam Talbot drophead coupe
2 1960s custom fiberglass race cars
Stewy
sa-club
Jeff Stewart
« Reply #3 on: June 21, 2012, 09:58:26 PM »
Hi Jason,
Some figures from the "60 Years of Holden"
FC Height     61" or 1,550 mm
Tyre size   6.40-13 x 4 Ply
Front Wheel track    54.5"  or  1,384 mm
Rear Wheel track     54.5"  or  1,384 mm
Rim size    13 x 4.50 J
Hope this helps
Cheers Stewy   Cool
my59
« Reply #4 on: June 29, 2012, 12:21:23 AM »
Hey Stewy and Pinky. Thank you for the help with the specs.
Very much appreciated.
Jason
FireKraka
« Reply #5 on: October 10, 2012, 12:52:51 PM »
Hi Jason;
How are you going with your application I have just received mine back. I am a bit confused because they said that they were not happy with my tyre choice but I had checked it on a tyre size calculator and it said that my speedo would still be in cal???
I'm wondering who are you going through for your engineering report.
Neil
