September 07, 2025, 07:28:46 AM *
Author Topic: Benchseat Floorshift  (Read 3041 times)
superfly
« on: May 03, 2003, 11:25:12 AM »
Hey everyone,
I was just wondering whats the go with fitting a benchseat to an fc that has had a 4 speed manual slotted in?
And also how hard is it to fit an EK steering column to an FC?
cheers Matt
FBvisitor
Don't ya' just love an old Holden
« Reply #1 on: May 05, 2003, 11:25:59 AM »
G,day Matt,
Regarding the seat, I have seen a notch about six inches wide and a couple of inches deep made in the front which looks spot on. Perhaps a trip to the seat trimmers is in order?
Cheers, Jason.
Digger
Classic not Plastic
« Reply #2 on: May 05, 2003, 11:58:59 AM »
G'Day Matt.
Check the tech info area out you might find it interesting
   "AUSSIE 4 SPEED ADAPTER FOR A BENCH SEAT"
http://www.fefcholden.org.au/techinfo/tech004.html
Steve
« Last Edit: May 05, 2003, 12:14:34 PM by digger » Logged
« Reply #3 on: May 05, 2003, 10:49:40 PM »
The EK column is a bolt in swap.  If you take the front seat out it can make your life much easier doing this, as it gives you a lot more room to maneuvre the column out from the firewall.
If you're planning on fitting the FC wheel to the EK column, it does shorten the column by about 3-4 inches (which I suspect is what you're after), but it means there is very little clearance between the seat and the bottom edge of the wheel for your legs!
Jonno
« Reply #4 on: May 06, 2003, 12:15:53 AM »
Hi Matt,
If you want to go with Jason's suggestion above, this is what it will end up looking like (also note EK column which, ironically, I want to take back to FE)
Jon
Cottles Bridge, VIC
Page created in 0.036 seconds with 17 queries.
