June 08, 2025, 07:02:12 AM *
Author Topic: Headlight surrounds  (Read 19631 times)
GM
« on: May 19, 2012, 09:39:33 AM »
Hi all, are all fe fc headlight surrounds the same? Can get some re-chromed ones but I'm a little worried they may not fit
           Cheers Glenn
Maco
« Reply #1 on: May 19, 2012, 11:02:34 AM »
Glen,
I believe there are 2 types Bosch & Lucas. The fit is a little different, found this when I did the resto on my car.
Better in Green
brett_f
« Reply #2 on: May 19, 2012, 11:34:08 AM »
Glenn,
When i was building my car i found the headlight surrounds to all be different shapes. Some fitted better than others. I had to mix and match to get the gaps right. I went through about 8 before i got two that were just about right. I then had these re-chromed. You might be happy with gaps slightly off but im a bit picky.
Regards brett
GM
« Reply #3 on: May 20, 2012, 03:21:47 PM »
Thanks guys, will look at re-chroming mine instead
weddo
HIS, HER's & OUR's
billnjudiwedd@gmail.com
« Reply #4 on: May 20, 2012, 05:44:19 PM »
If you are going to rechrome them Glen,you might be able to do some fine adjustments with the gaps by easing a bit off some metal with a light grind or file
regards
Weddo
Mc Bean
« Reply #5 on: May 20, 2012, 06:45:09 PM »
Hi all
Does the Bosch rims have a flat front edge, around 3mm & Lucas have a sharper front edge more pointed.
Andrew
Andy
« Reply #6 on: May 20, 2012, 07:12:18 PM »
Yes Bosch flat Lucas round
« Reply #7 on: May 20, 2012, 07:58:15 PM »
Easy way to tell - Lucas has 2 slots machined into the rim at the bottom where the lower screw goes in.
Stewy
sa-club
Jeff Stewart
« Reply #8 on: May 20, 2012, 08:26:34 PM »
And the bosch has bosch stamped into the back,
also has imported Germany.
But were they really imported?
Cheers Stewy   Cool
Dave Lakin (Davo Lako)
« Reply #9 on: May 20, 2012, 10:09:28 PM »
Woahh !!! ... This forum is "insane" for it's knowledge , helpfulness and detail !!!
When I was a young man I spent most of my money on cars , beer and women (in that order) ... the rest ... I just wasted !
Port Macquarie NSW
FE 4 ME
"A Sweet Sensation"
« Reply #10 on: May 21, 2012, 12:48:46 PM »
it's amazing just how much is gained from here...if i take mine off next time i will know what to look for
great stuff
FE 4 ME
KFH
« Reply #11 on: May 21, 2012, 05:35:17 PM »
To add further to the discussion.  At the bottom of the rim the Bosch has a single wide gap in the surround while the Lucas rim has two smaller gaps.
Stewy
sa-club
Jeff Stewart
« Reply #12 on: May 21, 2012, 10:17:22 PM »
I found one in the shed that has nothing on the bottom edge  Huh
also has no part number or manufacture details (not even HOLDEN)
in the casting. The casting is similar to the lucas one but is certainly
not the same. I only have one like it and it came off a wrecked FC wagon.
It has been chopped out with a grinder on the top inside so is not reusable
just another variation maybe ?
Cheers Stewy   Cool
« Reply #13 on: May 22, 2012, 02:44:38 PM »
Lucas ...
Bosch ... (I assume)
Port Macquarie NSW
« Reply #14 on: May 22, 2012, 02:58:12 PM »
Lucas ...
Bosch ... (I think) ...
Port Macquarie NSW
colt
« Reply #15 on: May 22, 2012, 05:08:20 PM »
The lucas ones have a small ridge around the inside edge also. Where they sit against the headlight. All my Bosch ones have Bosch and Made in Australia on the back. Reg. Design also.
colt
« Reply #16 on: May 22, 2012, 08:20:55 PM »
There is a third one which I had not mentioned because I don't know much about it - It has no marks on it and no cut outs on the bottom. Quite rare.
It does not appear to be original equipment but a later repro made by GMH as a replacement part maybe. I bought a NOS set maybe 20 years ago and put them on the 3 door van. Other than that I have only seen the odd one now and then.
« Reply #17 on: May 23, 2012, 04:43:34 PM »
Another Bosch ... different design at top ...
I recently won a pair of surrounds on Ebay ... one turned out to be a Bosch ... the other, a Lucas ...
Port Macquarie NSW
DN2168
See you on the road Skag!!
dean.nommensen
« Reply #18 on: May 23, 2012, 05:04:44 PM »
I have an each way bet...one of each  Roll Eyes.
Dean.
« Reply #19 on: May 24, 2012, 06:12:05 AM »
What's with the new name Dean Huh
Port Macquarie NSW
