September 09, 2025, 08:31:04 AM *
Author Topic: steering column  (Read 2439 times)
FC 304 wannabe
« on: May 01, 2012, 04:21:15 PM »
Hi guys , please help , I had rods racks modify my steering column for my fc . I have tried installing it recently and found that the inner shaft is too short.the steering wheel goes on but there's not enough thread left to put the retaining nut on ...
Has anybody else encounter this problem ?
Thanks,
Shannon.
FCV08
FE FC Club of QLD
« Reply #1 on: May 01, 2012, 11:02:57 PM »
Shannon
I also had the same problem and Rod advised to drill out the rivets and there is still a further 10-15mm available.
You need to tap the inner shaft a littel further out then redrill the holes into the inner shaft the re-rivet.
Hope this helps.
Craig D
FC 304 wannabe
« Reply #2 on: May 02, 2012, 07:21:44 AM »
thanks Craig,
you have been very helpful every time I post with a problem.....
I'll owe you a beer or two if I'm ever in your neck of the woods... Smiley
FCV08
FE FC Club of QLD
« Reply #3 on: May 02, 2012, 07:29:27 AM »
No problem Shannon
Page created in 0.038 seconds with 16 queries.
