June 21, 2025, 09:41:31 AM *
Author Topic: Starter Motor rebuild  (Read 9395 times)
Not Happy Jan
Aussie adventure
« on: April 25, 2012, 09:15:29 PM »
I took out the old starter motor and replace it with my one from the wagon... Wont need that one for a while Tongue Tongue
Anyway the standard kicked over no troubles after the swap Grin Grin
Today i took down the starter motor and first thing that I found was this as I pulled off the rear armature cover. There were other bits of paper in there but this was the biggest piece
The brushes had good contact but they were quite worn and one had  a knick out of the middle of it. . I have never seen the insides of a starter motor before so I don't know what they should look like or what should be clean etc. I have posted some shots of what I thought were susupect.
It did not have a seal for the armature cover and water has gotten in and the is rust on the parts as pictured.
Is this salvageable???
The inner coils that are screwed onto the casing had loose outer coverings and some of the outer covering was peeling off.
The retaining clip at the end of the spindle was loose. It did sit straight but had a lot of movement in it.
WHERE DO YOU GET NEW BRUSHES FROM?Huh
Nick
You can never have too many!
Port Macquarie NSW
zl296
« Reply #1 on: April 25, 2012, 09:48:54 PM »
find a old school auto elect.
machine/or clean up the com on the armature.
get him to growl the armature for shorts.
brushes/should be easy or file some to fit,
2 new bushes...
nearly reco for another 50000/mile.
 Cheesy
zl296
« Reply #2 on: April 25, 2012, 09:51:44 PM »
l reckon bosch make better starters/gennys
than lucas.
remember the germans nearly won the war..... Cry
Dave Lakin (Davo Lako)
« Reply #3 on: April 27, 2012, 10:28:43 AM »
Hey Nick ... Gary Bolton in Hastings River Drive did mine a few years ago ...  he's an old school spark ... 65841475
When I was a young man I spent most of my money on cars , beer and women (in that order) ... the rest ... I just wasted !
Port Macquarie NSW
Not Happy Jan
Aussie adventure
« Reply #4 on: April 27, 2012, 06:20:14 PM »
thanks Dave ... Ill give him a try... does he like it in bits?
Port Macquarie NSW
Mc Bean
« Reply #5 on: April 27, 2012, 07:22:59 PM »
Hi Nick
I just picked up some old Holden parts, including a Bosch  reco'd starter. Not sure if it is off a grey or red, U-EED 0,8/12 R37 ( can someone help).
IF it does fit a grey it owes me $30, it's yours if u want it.
Andrew
Andy
« Reply #6 on: April 27, 2012, 07:26:53 PM »
2 bolt grey 3 bolt red
Stewy
sa-club
Jeff Stewart
« Reply #7 on: April 27, 2012, 08:19:16 PM »
Hi Andrew,
The starter motor you have is a Bosch for FB,EK,EJ.  EEDO.8/12R37
FE,FC Bosch is EEDO.8/12R27     I don't know if they can be swapped, don't see why not.
Cheers Stewy   Cool
Not Happy Jan
Aussie adventure
« Reply #8 on: April 27, 2012, 10:15:46 PM »
Isn't it the other way round 3 grey and 2 red?Huh
And the EK starter has 4 brushes not 2 as in the FC starter and should not be a problem to interchange.
Port Macquarie NSW
KFH
« Reply #9 on: April 28, 2012, 09:43:26 AM »
The FB EK/Ej can be used instead of the one used on the FE/FC.  The look is identical apart from a small chamfer on the dust cover.  The later starter has 4 brushes and draws less current.  I used the 4 brush motor in my FC.
Not Happy Jan
Aussie adventure
« Reply #10 on: April 28, 2012, 10:11:08 AM »
Thanks All.  Grin
Port Macquarie NSW
Mc Bean
« Reply #11 on: April 28, 2012, 01:28:50 PM »
Thanks for the info Guys,
If it helps you out Nick, I can loan it to you for a while.
Andrew
Andy
Not Happy Jan
Aussie adventure
« Reply #12 on: April 28, 2012, 08:23:57 PM »
Andy
PM sent
Port Macquarie NSW
« Reply #13 on: April 29, 2012, 08:06:39 AM »
Ah sorry for the bum steer i know what im on about 3 bolt grey 2 bolt red....
Lucky i took drinking up again..
Pete
Page created in 0.042 seconds with 18 queries.
