May 24, 2025, 04:07:38 PM *
Author Topic: hanbrake cable setup .  (Read 2633 times)
FC 304 wannabe
« on: April 24, 2012, 08:34:36 PM »
Hi guys, currently trying to build the Handbrake Cable system on my fc.
I have a vn commodore diff and would like to use the original Handbrake lever in the cabin
. I have also got the vn commodore rear cable assy, and would like to use that.
Any suggestions?
I don't have the two pulley wheels used in the oem setup which will probably make things a bit more complicated.....
Thanks.
Shannon.
FCV08
FE FC Club of QLD
« Reply #1 on: April 24, 2012, 10:20:26 PM »
Shannon
I have fitted a shortened VN Diff and used the original VN cable. I also removed the out cable front mounts from the Commie and mounted them to the underside of the rear floor. Modified the front adjustment bracket from the VN and maunfactured the cantilever arrangement then welded the pivot and guide to the chassis rails either side of the gearbox.
I am fitting 304 Inj. motor so have manufactured a handbrake setup to suit the original underdash handbrake setup.
Prior to doing this resto I had a centre mount handbrake lever from an LJ torrie.
I sourced the two pulley wheels to run the front cable and put the original handbrake lever back in. Works great. Wink Wink
It is under 'Here we go again' in  project cars.
Good Luck
Craig D
brett_f
« Reply #2 on: April 25, 2012, 10:19:07 AM »
Shannon, I have the commo rear end in mine running the original handbrake and cable set up. For my conversion i used an original HG,T,K gear box support. Everything lined up and works a treat. The support can be seen in my build up. Some underneath pics may show the actual finished product but im not sure.
Regards Brett
FC 304 wannabe
« Reply #3 on: April 27, 2012, 01:23:38 PM »
thanks guys, appreciate your help...
